Clamp vs weld - Mustang Evolution
Old 10-02-2016, 10:24 AM   #1
Psmith129's Avatar
Clamp vs weld
Is having exhaust clamped on instead of welded just for lazy people or is there a benefit of it other than being easy to take off ? Is it more solid than a weld ?
Psmith129 is offline   Reply With Quote
Old 10-02-2016, 11:11 AM   #2
Revvv's Avatar
In most situations a clamp will work fine. Clamps allow for an easy install and disassembly if needed.
Is a weld better? A weld has pros and cons, just like a clamp. There is less chance of an exhaust leak if a competent welder does the job. However, if you ever want or need to remove the exhaust it will need to be cut.
Old 10-02-2016, 11:47 AM   #3
Psmith129's Avatar
Ah I see , I may be doing an off-road mid pipe down the road so clamping would make sense and will be less permanent . Thanks !
Old 10-02-2016, 01:24 PM   #4
Welding takes any rust preventative protection out of the material used so, that's why OEMs do very little of it. It also tends to harden the metal around the weld and make it easier for it to crack there.
Old 10-03-2016, 06:16 AM   #5
noldevin's Avatar
Usually no need to weld, but the oem sleeve clamps on the mid pipe usually don't work well once you remove them, I'd recommend replacing those with new ones. I keep having to re-tighten mine
noldevin is offline   Reply With Quote
Old 10-03-2016, 07:46 AM   #6
Strange Mud's Avatar
unless you have a good reason go with a clamp...all the above were good reasons not to weld.
Old 10-03-2016, 10:27 AM   #7
Senior Member
dgc333's Avatar
????? Almost all the joints in an OEM exhaust are welded. They only use clamps in locations necessary to install the system.
Welding stainless with stainless wire does not degrade the rust resistance.
To the OP, horse shoe clamps will crush the pipes making nearly as difficult as welding to take apart.
dgc333 is offline   Reply With Quote
Old 10-03-2016, 10:04 PM   #8
Psmith129's Avatar
Well i ended up using clamps and it seems pretty secure . Took my car down a fairly bumpy stretch of highway just to make sure it wasn't going anywhere and it's all good. Thanks for the help guys .
Old 10-03-2016, 10:06 PM   #9
Psmith129's Avatar
By the way , didn't realize what I was missing out on . I went from muffler deleted that would scream and shake your brain loose to the smooth and aggressive sound of borla s- types . I highly recommend . It's nice being able to not have to use sign language to talk to passengers
Old 10-03-2016, 11:21 PM   #10
Revvv's Avatar
I have considered leaving the cats and removing the exhaust.
Old 10-04-2016, 03:29 AM   #11
Psmith129's Avatar
Don't do it man , just from experience. The drone is unbearable , no to mention the vibration it gives off rattles the entire cabin . Sure it sounds mean when you step on it but it's very unrefined .
Old 10-04-2016, 05:31 AM   #12
noldevin's Avatar
Yeah that won't sound good at all lol. These cars need a good muffler to sound good without cats
Old 04-15-2017, 09:51 PM   #13
Boss302PR's Avatar
The stock components of the exhaust seem to fit up nicely with other stock components so clamps work fine but when you add aftermarket parts and connect them to stock parts the fit isn't perfect and you may get leaks.
The guy at the muffler shop near my house suggested welding when you have a mix/match setup to avoid leaks. He always suggests installing every component of the same brand to ensure proper fit.
Boss302PR is offline   Reply With Quote
Old 04-16-2017, 08:46 AM   #14
Beviking's Avatar
I use Permatex muffler and tail pipe sealer and the band style clamps. Sealant helps lube the connections when putting them together and dries fairly quickly. It won't patch a hole but works well ime for connections that use clamps.
'12GT Premium, Roush TVS & BAP, VMP Elbow, 82mm, JLT CAI & Catch Can, Eiback Sports, Steeda Cambers & Adj UCA, Adj panhard & Brace, LCAs+Relos, Diff Bushing, Ford Diff Cover, Axle Catch Can, 3.73, Shaftmasters DS, MGW, BG Syncro II, Blowfish Shifter Support Bracket, Trans Mount Insert, MBRP 3" H pipe, Borla 3" Touring Pipes/Axlebacks, High Flow GT Grill Insert, Steeda Spyder Wheels (20X9.5/11), 275 fronts, 315 rears, Lakewood drag shocks, Cervini Hood, big smile
Beviking is offline   Reply With Quote
Old 04-25-2017, 11:56 AM   #15
I agree on the sealer. I have used it on a several systems, and it does dry extremely fast. I have had to take apart a system that was just sealed about a week, and had to really use force to remove the ends. The sealer sets up pretty hard, and reduces the likelihood of any leaks. You can always go back and test it for leaks when done.
StangLife is offline   Reply With Quote
cut and clamp x? p_gehle41 2005-2010 Mustang GT 6 08-22-2013 02:50 PM
Billet grille replacement vs. clamp-on? Fader 2005-2010 Mustang GT 2 08-08-2013 04:29 PM
fuel pressure sensor clamp samuelsmith Mustang Parts for Sale and Wanted 0 04-26-2013 11:04 AM
Steering shaft clamp and bolt 2.3Foxbody 2.3 Mustang 5 11-16-2012 04:23 PM
Ford racing clamp on x-pipe godsdisciple85 2011-2014 Mustang GT 8 12-20-2011 12:24 PM
07:58 AM
