I just put my jba cat delete pipes on my stock h-pipe. I used clamps and I am having major exhaust leaks on both sides. I really do not want to weld them on, is there anyway to stop the leaks without welding?
Maybe a different type of exhaust clamps. A pic would help people diagnose the potential problem.
If you bent the exhaust pipes by over tightening, it's probably too late to fix without welding. You could try use exhaust wrap and see if that fixes the problem, but that could be a temporary solution only. Welding will fix it for sure, but please post a pic if you can.
The problem was that the jba cat delete pipes ended up being a little bit shorter that the stock cats so I had to take it to the exhaust shop and I just got them to weld them on.
For whatever reason, it seems like once the factory clamps are disturbed they never seem to work very well afterwards.
These can be found at NAPA. Fold aluminum foil 3x over, about the width of the clamp and make sure it goes around the joint twice. Then put this clamp over the top of it and tighten it down. Problem solved.
I have searched high and low for replacement clamps and I'm sure the aluminum foil with the larger clamp works.
When installed the x-pipe, I reused the clamps and I've always had a slight leak on start up that goes away in 30 seconds or so.
Anyhow, I know someone here had a part number for napa or somewhere and I've never been able to locate it. And I put a post out there looking for it and the only response I got was the condescending "search engine is your friend" Well the search engine is not very friendly as it returns a million posts with nothing related!
Anyhow if anybody has a source for a replacement factory type clamp please respond with supplier and P/N.
I actually found one by turco and contacted a sales engineer, he tod me they are available from Napa but when I go to the store and website they can't find them.
Not quite, I think those are similar to what the poster above noted, with an aluminum foil wrap.
Supposedly the same type of OEM clamp is available aftermarket.
Just cant find it.
Well the NAPA near me has them hanging up in easy reach. They're wider than 2.5", more like 3-4", I can't remember.
Keep in mind - from my experience these clamps can only be taken off and re-used maybe once. You can re-foil the joints and it will work, but always do your best to put them back in the same positions. Otherwise you'll find in a couple thousand miles the foil will start to blow out and it will leak. These clamps will take a set and form to everything once you cinch them down.
I've replaced mine once already, but that was from me taking them off and on a couple times for other reasons. The ones on the car now have been on there for almost two years with no leakage or problems.
I'm putting long tubes on this Saturday and will most likely just replace them to avoid any problems down the road.
When I buy the clamps in a day or two I will take a pic of them for you to see.
Have fun installing those long tubes. If the install is anything like the one I did in my driveway on my '07 GT, your neck will hurt when you're done and you'll have used every curse word you know at least a few times. Totally worth it.
Jegs sells them. I bought a new one off there. The stock clamps are junk and will always leak. Just buy a complete off road x or h that eliminates the stock ball and socket nonsense. I've tried foil, dryer exhaust tape, furnace cement, and muffler cement. It usually stayed good for a week or two then after a wot or me using my 2 step it would go to leaking again.
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
