hey guys, I'm hoping to find someone that might have gone though same issue as me. I know there's hundreds of posts about limp mode, I've read them and tried almost everything recommended.
I recently built my 2012 motor and swapped mt82 to 6r80. Programmed ECU and crank relearn at dealer. Then tuned car with AED. Replaced throttle body/tps, tested alternator, tried multiple batteries.
Here's the problem:
1. Car turns on and idles fine.
2. Shifts up to 1500s rpm fine except it runs poorly because of limp mode I guess.
3. No throttle response for like 20 seconds unless I move shifter to (D, R, 1, 2, 3) the throttle response comes back instantly.
4. Most of the time, no codes come up. Unless I drive for a while (10 mins) and rarely the code p0011 pops up.
Here's the problem:
