Just got a FRPP 624 kit, what next? - Mustang Evolution
Old 02-18-2017, 09:38 AM   #1
Region: New Mexico
Hello all, I've slowly been modding the car over the last 2 years. So far i have done the following:
Shocks/struts, C&C plates, springs (sport line), lca, uca, pan hand bar, SS brake lines, SS clutch line, dot 4 fluid, resonator deletes, gt500 AB, oil cooler, gt500 rear rotor upgrade (will install on next brake job), and bought the car with the Brembo brakes.
This week I just purchased the FRPP 624 SC'er (manual only) kit and am wondering a few things. First is, what else should I do for reliability as she is my DD. I am not chasing more power at this time so tune/intake/exhaust are not really consideration unless they help something in missing.
For example, I currently have 3.73's and know I should drop, but to what?
Please let know what I'm missing.
Sent from my SM-G900P using Mustang Evolution mobile app
slimguns is offline   Reply With Quote
Old 02-19-2017, 11:31 PM   #2
Jn2
You will need a clutch soon after, stock clutch can handle the torque for a while, but your mileage may vary depending the age of your current clutch. As far as gearing, since you have a MT82 you will want to drop to 3.31.
13' Mustang GT w/Track Pack: Bottle fed CJ manifold, FRPP Intake,FRPP Monoblade TB, Speedmaster headers, Magnaflow 3" X pipe, Bassani quad tip ABs, Jn2uned, SRP Axles, MGW shifter, BMR LCA's
Jn2 is offline   Reply With Quote
Old 03-20-2017, 10:12 PM   #3
Region: New Mexico
So after driving it a bit gears and an upgraded clutch is on my short list. So, how hard are those in a garage? Can a shade tree hobbyist complete either job? So far I've done all suspension work (panhand bar, lca, uca, struts, shocks, springs, cam/cast plates), mgw shifter, x-pype/axle backs, and the kit that started this thread.
Thoughts?
Old 03-21-2017, 12:43 AM   #4
Still racing. ..
Number29's Avatar
Are your shocks/struts adjustable. ?
And why would you want to change from
3.73 gears..?
(Just curious. ...)
2012 Boss 302
Performance white
Goodyear Eagle F1 tires
Number29 is offline   Reply With Quote
Old 03-21-2017, 05:55 AM   #5
noldevin's Avatar
You would change from 3.73 gears because they are usually too much for boosted cars.
noldevin is offline   Reply With Quote
Old 03-21-2017, 06:50 AM   #6
Region: New Mexico
The 3.73's are/were great for NA but as so many before me have stated (and I found true) they are hard to control on a PD blower.
I am a firearms enthusiast and related throttle control to trigger control and thought "I'll just use self control and throttle control, it'll be fine". What I find is it's like having a two ounce trigger on a duty weapon that you are required to keep on target and "at the ready" while driving on a dirt road in Iraq all the while without firing. Accidental discharges would be next to impossible to negate.
Same thing here, even being conscious about it the tires spin too easy.
It's fun in fourth and fifth gears with surprising acceleration but even third spins. ..
Old 03-21-2017, 07:54 AM   #7
Rapinator126's Avatar
It's all about traction and what your shift points are at. And what you use the car for. I had 4.10's with close to 800 ft-lbs and was manageable for what the car was intended to do.
Old 03-21-2017, 09:11 AM   #8
1 Alibi 2's Avatar
Put 3.73's in the 14, ( stock was 3.31 ), greatly improved the driving experience.
Several owners on the SVTP site did 4.10's..
2014 - detuned to 780rwhp
2017 F150 Lariat Scab, 5.0
Old 03-21-2017, 09:14 AM   #9
noldevin's Avatar
If you're referring to a shelby, they have much longer gears than an mt82 so the effect is much less drastic. 3.73s and 4.10s only make sense on a boosted coyote if you have a well sorted drag setup and are trying to dial in finishing in a certain gear
Old 03-21-2017, 09:24 AM   #10
Grabber Blue5.0's Avatar
Different transmission with different gearing. It's not even remotely a fair comparison.
Yes a few Shelby owners put 4.10's in but we're talking 1% of the owners from that site.
Old 03-21-2017, 10:51 AM   #11
Clutch in the garage... technically yes... have fun bench pressing the trans in and out tho or getting a jack under there with the car 2ft in the air on jackstands. Screw that. If you have lift access and know what you are doing its an afternoon job tho.
Old 03-21-2017, 02:47 PM   #12
It's not that hard. Actually it easy.
Old 03-22-2017, 08:13 AM   #13
I don't like doing transmissions in the garage... I'm spoiled and have lift access tho. I don't even rotate my tires with a floor jack anymore lol.
Wanted: FRPP TB, FRPP Manifold, JLT Series 3 110MM Borii Mustang Parts for Sale and Wanted 2 09-21-2016 06:21 PM
For Sale: RTR 1.5" Lowering springs, FRPP pan-hard bar, FRPP lower control arms, silverhorse RTR Mustang Parts for Sale and Wanted 25 04-22-2015 10:38 AM
FRPP Boss 302 Style Side Exhaust Kit. mustangz 2011-2014 Mustang GT 32 11-27-2013 09:00 PM
frpp c or eibach pro kit carlosc Pre-2005 V6 Mustang 7 01-19-2009 09:18 AM
04:47 AM
