I am looking to upgrade the suspension on my 2011 Mustang GT and was wondering if anyone else has used the following parts as a setup
1) 2005-14 Ford Mustang Ford Performance Lowering Spring & Strut Mount Kit GT - S197 from LMR (these are M-5300-KA springs)
2) Koni Orange Struts & Shocks
2a) On the description for the springs it says you need to order the 2005-2010 Struts & Springs when used with the Ford Performance springs and GT 500 mounts, and a call to LMR confirmed this, but if you ask AM about the same parts they say only Ford Performance Struts/Shocks can be used.
So my question is has anyone tried this setup and how has it gone?
I am adding LCA's, UCA, Panhard Bar & Brace, End Lings, Bumpsteer & Sway Bars as well, so have that covered.
I have the 2005-10 koni orange struts with GT500 mounts, and it works great. Just make sure you have the arrows on the strut mounts pointing opposite of how they install in the GT500, and your alignment should be fine. I also have steeda springs which are only a 1.5" drop, and a steeda upper with BMR lowers, and an adjustable phb.
You dont need the UCA unless you have a 1 piece driveshaft.
You dont need the panhard bar brace.
I would skip the sway bars and end links, unless you're sure you know how to adjust them properly - and i'm not sure what type of driving you'll be doing, but im not sure these will be worth the money you're spending.
Definitely do not get the bump steer kit unless you know how to install it properly, or it will make things worse.
Just stick with the lower control arms, and add lower control arm relocation brackets at this time. If you're still not happy with the ride, then you can see about adding other parts. Even then, i would only get a front sway bar, but that's probably a discussion for another thread.
Thanks all for the advice & tips, completed the mods last week.
Front & Rear Ford Racing Sway Bar, End Links, Koni Orange Struts and Shocks, Ford Racing K Springs, BMR LCA & LCA Bracket, BMR Panhard Brace & Bracket.
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
