Need troubleshooting help - some rear bushing I think - Mustang Evolution
Old 09-22-2017, 12:58 PM   #1
AXG
AXG's Avatar
Hi All...
I think one of the rear bushings went out the other day and need help with how to determine which one (SB end links, UCA, or LCAs...not sure). I'm getting a rattly/clunky sound when driving over bumps near rear passenger side. It seemed to literally happen overnight... I never heard it before, then next morning it was there. I only hear it when driving over bumps/bumpy road. I'm not sure it's a bushing, but that's what it sounds like to me.
Any troubleshooting tips or what to look for if I get under the car would be great...thank you.
2013 GT - Steeda sport springs, Steeda ph bar, Steeda Pro-action shocks/struts.
Arlen.
AXG is offline   Reply With Quote
Old 09-22-2017, 02:33 PM   #2
Voltwings's Avatar
jack the rear up and use a rubber mallet to smack stuff until you find it.
Old 09-22-2017, 02:51 PM   #3
AXG
AXG's Avatar
Cool...that seems pretty straightforward.
Old 09-22-2017, 04:22 PM   #4
Revvv's Avatar
Volt goes straight for the hammer. Just beat it with a hammer. A hammer takes care of everything. 🤣
Old 09-22-2017, 04:51 PM   #5
Voltwings's Avatar
I've lost patience over the years lol.
Old 09-23-2017, 09:09 AM   #6
AXG
AXG's Avatar
Banged on stuff.... couldn't find anything. Not really sure how to check the UCA. Are there any other details, etc. that could help narrow it down?
Old 09-23-2017, 11:09 AM   #7
Voltwings's Avatar
do you have aftermarket mufflers? Those ball clamps on the axle back / muffler connection come loose from time to time.
Old 09-23-2017, 01:03 PM   #8
Beviking's Avatar
I think you'd be hard pressed to get any noise out of a worn differential bushing by using a rubber mallet. It's a tight area up in there. If you did get a good swing on the UCA, by using a 1" dia wood handle (broomstick etc) and a hammer from where you could swing (below the DS) you might hear something.
The rest of the bushings are easy to get to so by process of elimination, I would think it's the UCA, one end or the other.
'12GT Premium, Roush TVS & BAP, VMP Elbow, 82mm, JLT CAI & Catch Can, Eiback Sports, Steeda Cambers & Adj UCA, Adj panhard & Brace, LCAs+Relos, Diff Bushing, Ford Diff Cover, Axle Catch Can, 3.73, Shaftmasters DS, MGW, BG Syncro II, Blowfish Shifter Support Bracket, Trans Mount Insert, MBRP 3" H pipe, Borla 3" Touring Pipes/Axlebacks, High Flow GT Grill Insert, Steeda Spyder Wheels (20X9.5/11), 275 fronts, 315 rears, Lakewood drag shocks, Cervini Hood, big smile
Beviking is offline   Reply With Quote
Old 09-23-2017, 02:46 PM   #9
AXG
AXG's Avatar
I'm going to go back and check again.... it's definitely coming from around the rear passenger wheel. I read somewhere that one dude disconnected the suspected Swaybar link to verify, but that seems unsafe to me especially on a lowered car.
Old 09-23-2017, 03:20 PM   #10
RBK
My end link bushing was bad and caused a clunk noise. Took forever to figure it out as it did not seem loose. I would start with them.
RBK is offline   Reply With Quote
Old 09-23-2017, 04:08 PM   #11
Voltwings's Avatar
It's perfectly fine to have no sway bar on the car unless you're turning at a high rate of speed. I took ours off due to a track incident years ago and just ... never got around to putting it back on haha. I will at some point ...
Old 09-24-2017, 11:03 AM   #12
AXG
AXG's Avatar
It was the adjustable PH Bar! One of the jam nuts was loose. I'm surprised it caused that much clunking at the rear passenger wheel. It really sounded like a bad bushing to me. Thanks for the info...it helped me narrow it down.
Old 09-24-2017, 11:36 AM   #13
olerodder's Avatar
Region: Oregon
One trick we used to do...and I still do on any suspension bolts/nuts...mark along the flat of the nut and a mark corresponding adjacent to flat. This will give you a visual reference and tell you if any of the nuts/bolts has moved. I have used this method in drag racing for over 40 years and also in SCCA racing since the early 2000's. Funny story...I was racing my Camaro in NHRA SS/IA at SIR and looked under Grumpy Jenkins car and saw this method of marking suspension parts...at about the same time I stuck my head under the car Mr. Jenkins told me in no certain terms to get my "Big Fat XXXXXXX Head out from underneath his car"!
Old 09-24-2017, 03:04 PM   #14
Beviking's Avatar
Great suggestion from olerodder, no surprise there.
That's a case of not supplying all the info (but what are you going to do, list everything you've ever done!?) which could've helped. I have adj panhard and adj lca's. Had a nut loosen on a lca and it clunked for part of a day.
Old 09-24-2017, 03:26 PM   #15
Voltwings's Avatar
Did you lock tite those nuts?
Old 09-24-2017, 09:16 PM   #16
AXG
AXG's Avatar
I didn't install it.... but it didn't look like they were. I'm definitely going to now.
Old 09-25-2017, 09:49 AM   #17
REG
Pan hard bar
Until you tighten down the nuts they will clunk pretty good!
So if one worked loose, I can see it clunking pretty good.
OLD RODDER
I think Grumpy has passed but his shop is still being run by his sons.
They moved it from Malvern to north of Philly.
I have an acquaintance in NJ who's part owner of a Gen 2 camaro who they built an engine for.
It was making a hell of a lot of horsepower and he said all they've done is break $h!t this year.
2013 BBK Short tube, E-Force Stage 2, M/T 245/18/40 DR's, BMR LCA's, Alum D/S, Strange FRT adjustable struts
REG is offline   Reply With Quote
Old 09-25-2017, 09:51 AM   #18
REG
One more response for Voltwings
If that don't work, get a bigger hammer!
Old 09-25-2017, 10:27 AM   #19
AXG
AXG's Avatar
I was really surprised it would make that much noise.
Old 09-26-2017, 08:53 AM   #20
REG
Clunk
Hadn't done the final adjustment and we took it out on the highway and it clunked several times on even small bumps, once set and thread locked no clunking through a couple of hundred miles
UCA bushing replacement + Steeda trans bushing install Voltwings 2011-2014 V6 Mustang 0 10-11-2015 06:09 PM
Rear lower control arm bushing noise RWSRWS 2011-2014 Mustang GT 2 09-20-2015 08:05 PM
For Sale: Bmr adjustable rear upper control arm - poly bushing (11-14 all) Mean14 Mustang Parts for Sale and Wanted 4 05-22-2015 10:37 AM
Rear upper bushing sleeve 94_2valves 1979-1995 Mustang GT 5 06-01-2013 04:28 PM
Poly rear axle housing bushing 04machazblue 1979-1995 Mustang GT 8 01-11-2012 11:12 PM
09:37 PM
