Bias ply or drag radial - Mustang Evolution
Old 10-14-2017, 04:54 PM   #1
So I?m getting some 15x10s and I do mostly street racing and It?s a stick car I hear bias ply is the way to go so you don?t break axles and stuff but then I hear drag radials are good for street for a stick car but not the track.
Need some help figuring this out I hear mix match reviews about this thanks in advance
3.7 silvrbullet is offline   Reply With Quote
Old 10-15-2017, 04:58 AM   #2
Grabber Blue5.0's Avatar
A manual car needs a slick at the track but if you're going to only use it for the street then a drag radial will be fine.
And please don't do any street racing, take it to the track.
Old 10-16-2017, 10:28 AM   #3
Ja5.0n's Avatar
Currently running 28X11.5-15 MT ET Street R bias plys without tubes. They hook pretty well. Only down side is they wear out real quick. A radial will last longer.
Ja5.0n is offline   Reply With Quote
Old 10-21-2017, 10:07 AM   #4
You will likely cut a slick at some point if you run it on the road, plus it'll handle and brake sketchy. Radial for road but, you will be giving up alot at the strip unless you have a slick, particularly on stick cars.
Old 10-23-2017, 09:01 AM   #5
Drag radials
I'm running mickey Thompson et street SS 305/40-18 drag radials on my roush charged 2014 GT with 6 speed manual. 550hp and 500ft lbs of tq at the wheels. Ran a bunch of 11.4s @ 127-129mph in the last couple weeks. Both Keystone raceway park and quaker city over the past 2 summers. Prob total of 60-70 runs, nothing broken. Knock on wood. I also drive to and from the tracks with them on about an hour each way. I did pull over the one time it rained hard. they are a bit scary.
rmoeslein is offline   Reply With Quote
Old 10-23-2017, 10:19 AM   #6
3SevenStangVids's Avatar
slick for stick radial for auto. radials are much harder and will destroy your rear end over time on a manual + launching hard. I found initially a tire like et street gave me great grip ( i was pulling the wheels on a 3.7 clean off the ground) but only lasted for about 10 passes then they went to ****. Had radials on my 5.0 with a tune and midpipe and dead hooked every pass (auto) lasted untill you could almost see the radials coming through. As i've always been taught, slick for stick, radial for auto.
2012 3.7L MCA 13.09 @ 106.66 MT82 MPT93 BBK LTH ORX ATAK 73MMTB LONEWOLF INTAKES BBK CAI FRPP 3.73 AE 1PC DS J&M LCA'S STS+2POST CLUTCH SPRING DELETE STRANGE 10WAY SHOCKS SOLD
2014 5.0 MUSTANG - 12.1 @ 116.5 6R80 3.15'S MPT93 LETHAL ORX CUSTOM 3" OTA VIKING SHOCKS UCA LCA
2012 3.7L BASE -MPT93 STEEDA CAI BORLA STYPES
3SevenStangVids is offline   Reply With Quote
Old 10-23-2017, 02:00 PM   #7
REG
Hi jacking thread
3sevenstangvids, what size DR you running?
I have a 245/18/40 MT DR and it ain't hooking up.
Prior to EFORCE, 12.4 was best time with pro cal, one piece shaft.
With Eforce, 11.5 and I know its breaking loose going into second.
Thought about 275's, they'll fit on the rims I got (18X9) but anything bigger obviously need bigger rims.
Anybody else. Pinion angles at -2, lowered an inch in the rear. BMR LCA's
Stange engineering adjustables up front, set lowest level.
2013 BBK Short tube, E-Force Stage 2, M/T 245/18/40 DR's, BMR LCA's, Alum D/S, Strange FRT adjustable struts
REG is offline   Reply With Quote
Old 10-23-2017, 02:19 PM   #8
You need more sidewall on those tires. You can go width all day if you're still on a 40 sidewall its not going to help. I had 275/60/15's on both stangs the 3.7 being manual and the 5.0 auto. Had the et street SS on the last few passes with the 5.0 and dead hooked no problems. Going with a similar size on this project 3.7 im doing but its going to be a bias ply for sure.
Old 10-24-2017, 11:35 AM   #9
REG
15"
You say you ran it on the 2014 5.0 what 15 " rim, 15X9 or 15X10 and who made it and how much offset and did you need to relocate the sway bar brackets?
I think a 275 would be great size but I've seen mixed bags on 15" rims fitting.
If it worked on your 14 it'll work on my 13.
Thanks!
Old 10-28-2017, 06:31 PM   #10
Even on the street? Cause I do mostly street racing
Old 10-29-2017, 02:12 PM   #11
I have a 2014 . I'm running a MT drag radial 325/50/15. Mounted on Weld RT-S 15X10 rims. I don't recall the B.S. but call Weld they can tell you exactly what you need. And I did need the relocation brackets (about$40) and easy to install.
bodon is offline   Reply With Quote
Old 11-01-2017, 10:45 AM   #12
REG
Wheels
Found something similar on LMR site, they say relocations are required as well.
Thanks for getting back to me Bodon.
Drag radial on a 19 9.5 Ibad5.0 2015 Mustang GT 2 05-19-2016 07:33 AM
Drag radial help Ibad5.0 2015 Mustang GT 3 05-17-2016 12:16 AM
Drag radials or bias ply tires for track? Daveauth21 2011-2014 V6 Mustang 3 10-16-2014 03:30 PM
The best drag radial ? 2003CobraSvt Mustang Paint, Appearance & Detailing 3 11-02-2011 09:53 AM
drag radial help godsdisciple85 2011-2014 Mustang GT 19 10-05-2011 05:28 PM
07:15 PM
