Accufab/BBK tb on 2013/14, 5.0 - Mustang Evolution
Old 12-10-2017, 12:53 PM   #1
Anybody switched out there tb to either an accufab or BBK 85mm tb?
If so, could you tell any difference in response? My 2013 has 68,000 on it, and recently there is an ever growing lag in throttle response, so I am going to switch out the tb and get a new tune to local 93 octane at the same time, as I moved 1/2 way across the county and my last tune was on 91.... so back to my original ?, anybody running n/a and swapped the stock one out yet?
santej25 is offline   Reply With Quote
Old 12-10-2017, 01:13 PM   #2
noldevin's Avatar
Stay away from the BBK.
Odds are you probably won't notice much difference on a new tb. If your throttle response is decreasing i'd do a datalog with your tuner and see what they can find.
noldevin is offline   Reply With Quote
Old 12-24-2017, 06:59 PM   #3
Not sure why noldevin said stay away from the BBK specifically. It works fine. I bought mine used and have run it in my car for over 2 and a half years, zero issues.
That said, don't waste your money on the throttle body. Look into the tune, a throttle body isn't going to make much difference.
Stock TB is 80mm and the manifold opening is 83mm. At wide open throttle the inlet diameter is only increased by 4% over stock. At part throttle where throttle body size might make a difference, you might be opening that inlet an extra 1-2%
No one will feel or notice 1% more throttle opening on a stock manifold coyote. Big throttle bodies have more benefit for cobrajet manifold or positive displacement blowers.
nate714 is offline   Reply With Quote
BBK Varitune mufflers on 2013 V6 Ponyboarder 2011-2014 V6 Mustang 12 08-23-2016 09:09 AM
2013 bbk shorty header instal help! REG 2011-2014 Mustang GT 3 05-19-2014 09:07 AM
BBK TB vs ACCUFAB TB??? DARK.STANG 1996-2004 Mustang GT 4 04-24-2013 06:10 PM
Accufab Upper Intake or BBK throttle intake? mustangmar2001 1996-2004 Mustang GT 3 02-06-2013 04:59 PM
2013 v6----air raid or bbk? polasky 2011-2014 V6 Mustang 18 10-19-2012 10:32 AM
12:48 AM
