Tire choices for 18x11 wheels - Mustang Evolution
Old 01-21-2018, 01:34 PM   #1
What a PITA.
I am looking for tires for a set of Forgestar F14 18x11 wheels.
It was suggested to purchase 315/30 which seems to limit my options, but it looks like 315/35 may also be an option with a speedo calibration.
Nitto NT01 are offered in 315/30. I hear that Mickey Thompsons are good, but I am struggling to find the size for street legal use.
Any recommendations for 315/30/18 or 315/35/18 on an 11" wheel for street use that hook good?
Hoosier? Toyo? Kuhmo?
Conspiracy is offline   Reply With Quote
Old 01-21-2018, 04:33 PM   #2
The actual speedo difference between 315/30 and 315/35 will be nil. If you are that worried about the speedo being off, use a gps app on your phone to see how far off you are and if its too much for you get a tune.
A Mickey Thompson Street comp 295/35/18 will fit just fine and is 100% street legal and hooks well. 11.9" section width so it should be flush but not "hella flush" which will also help ensure you don't get any rubbing.
Old 01-24-2018, 10:47 AM   #3
Voltwings's Avatar
What are you trying to accomplish with these tires? Don't just think a sticky tire is sticky, if you try to take an NT01 drag racing, you're going to have a real bad time with the stiff sidewall.
Old 01-24-2018, 11:39 AM   #4
Shhh... This is the internet we only accept advice from ppl who have "done their research".
Sent from my LG-LS997 using Mustang Evolution mobile app
Old 01-24-2018, 11:34 PM   #5
NewMtang's Avatar
Tire Size
Originally Posted by Conspiracy View Post
What a PITA.
I thought you could only use 10" wide on the rear, unless your using an offset rim? Help me Scotty....
Old 01-25-2018, 01:29 PM   #6
This is, in part, what I am trying to understand and hoping someone can educate me on what I need based on what I want to do.
I'm looking for a tire to fit an 11" wheel that hooks well on the street and the strip (I occasionally go).
My reasoning is that my *** end breaks loose and I am hoping a tire will help (might not be the be-all-end-all), but certainly help hook well.
Currently, I run a 20x10 on Continental DW.
Old 01-25-2018, 02:34 PM   #7
Voltwings's Avatar
Power? Transmission? Suspension setup?
Old 01-25-2018, 02:38 PM   #8
Rapinator126's Avatar
There is a guy that use to be on here, that is running 18×11's with 315/30's on all 4.
Sent from my SAMSUNG-SM-J727A using Mustang Evolution mobile app
Old 01-25-2018, 03:01 PM   #9
600 RWHP, auto.
Suspension is in progress. It will be updated along with the wheels and brakes.
I have an existing track suspension from Roush which will be updated with Vorshlag-Billstein Street Pro 1.5" drop front/rear.
Old 01-25-2018, 03:44 PM   #10
Auto 600 hp... get ET streets...
Old 01-25-2018, 03:45 PM   #11
Voltwings's Avatar
600 RWHP, auto.
My main concern was lowering springs without relocation brackets and or lower control arms.
If you're lowered even a little, the relocation brackets are a must, and the poly lower control arms will help as well. The Vorshlag Bilstein combo is an excellent choice.
Old 01-25-2018, 03:53 PM   #12
I do have the Roush upper and lower control arms; no relocation brackets though.
Vorshlag had an excellent write up about their 18x11 setup and had it lowered (I believe) more than 2" with no rubbing issues.
I have been eyeing their 18x11 for the rear only as well as their V-B combo with 1.5" drop F/R for some time.
I'm now trying to find some good rubber that will provide a better hook for predominant street with strip use.
Old 01-25-2018, 06:13 PM   #13
Voltwings's Avatar
The best tires in the world wont save you without relocation brackets. That being said, The MT mentioned above is a good choice.
Old 01-26-2018, 10:36 AM   #14
Can you elaborate as to why? Roush doesn't require them, but I presume Roush is on the edge of spec where it is not required.
I already have a BMR pandhard bar upgrade going in as well, and their lower control arms and brackets are not expensive.
Old 01-26-2018, 11:08 AM   #15
Voltwings's Avatar
In a nutshell, one end of the LCA bolts to the body, and the other to the axle. If the LCA is parallel to the ground, when the vehicle transfers weight to the rear, it will take the weight of the body and put it on the axle.
When you lower the car, you lower the body relative to the axle. Now, when weight is transferred, the body mounting point of the LCA is below the axle and will actually pull weight off the axle during weight transfer. That's what i mean by no tire will help if your geometry is off.
Old 01-29-2018, 11:15 AM   #16
I'm going to by annoying with another question.
Now that suspension advice has been included, I have a question about tire width.
For an 18x11 wheel, Vorshlag recommended a 315/30 for their 18x11. People in this thread have recommended MT's EE streets, but I cannot find that size nor am I knowledgeable enough to know what would be an equivalent fit for a 315/30 tire.
Any advice?
Old 01-29-2018, 11:34 AM   #17
Voltwings's Avatar
Keep in mind that Vorshlag is also recommending a tire from a handling perspective. Typically you want a tire that is equal to, or about 1/2" narrower (on a 315 might even be able to get away with 1" narrower) because the slight sidewall "stretch" actually provides some preload and stability in the corners. For straight line traction, you can meet or even very slightly exceed rim width with your tires, but keep in mind, tire too much outside the rim really isnt in contact with the road much, so dont pay for tire you arent using.
Tire rack lists the "specs" for the tires they sell, so you can measure the tread width there.
This Falken i've linked (hopefully) for example is listed as a 315/30/18 but actually runs about 11.5" wide, which could work. Note* That falken is a good tire, but i was using it as an example more than explicitly recommending it.
https://www.tirerack.com/tires/tires...omCompare1=yes
Old 01-29-2018, 11:56 AM   #18
So let me think out loud to make sure I understand. I need to deal with measurements, so it is clear in my mind.
315mm is 12.5", so based on that there will be 1.5" of "extra" tire on an 11" wheel.
So, theoretically, a 285/xx could be possible as 285mm is 11.22". Correct?
That will give me greater options as I have been trying to zero in on a 315/30 and it has been so painful as options are limited. If I can look at a 305 for example, that would be great.
Old 01-29-2018, 12:22 PM   #19
Voltwings's Avatar
Dont confuse section width and tread width. You cant strictly convert MM to inches in relation to my previous post.
Old 01-30-2018, 01:33 PM   #20
Ok, since I am dumb, I pulled up a tire calculator.
https://tiresize.com/calculator/
I currently have 275/35/20 on the rear and at least according to the calculator a 305/40/18 is almost identical for height.
Because Google is creepy, the adds immediately show a MT EE Street S/S in a 305/40/18. I think I am set.
Thanks for the help.
Old 01-30-2018, 03:22 PM   #21
Voltwings's Avatar
Awesome. Keep us posted.
AMR tire choices? zachalyse Mustang Wheels & Tires 11 04-28-2017 09:54 AM
TIRE CHOICES. Opinions appreciated TurboCobra Mustang Wheels & Tires 3 06-30-2014 03:48 PM
18x11 Thejustang SVT Mustang 3 11-26-2012 11:40 PM
Wheels choices GoldenPonyBoy Mustang Wheels & Tires 24 04-30-2012 05:36 PM
All about Wheels/Tires! From size to rim choices SpectorV Mustang Wheels & Tires 14 03-17-2005 01:19 PM
03:35 PM
