Scraping sound coming from rotors? - Mustang Evolution
Old 02-13-2018, 09:58 PM   #1
I own a 2012 GT with under 8K miles and everytime i make a right hand turn there is this tin-like scraping sound. More like a scrape scrape scrape with a cadence that speeds up and slows down with speed. When i straighten the wheel it doesnt make a sound. Any ideas?
Smjoens is offline   Reply With Quote
Old 02-13-2018, 10:41 PM   #2
Cooolbreeez's Avatar
Happened to me the other day when I was turning right too. It sounded like I was dragging a soda can. I stopped to see if I ran something over but there wasn’t anything there. Looked under the car when I got home and didn’t see anything. That’s the first time it happened, hasn’t happened since. I have a 2014 mustang gt with just under 43k miles on it.
Cooolbreeez is offline   Reply With Quote
Old 02-14-2018, 06:48 AM   #3
Might be worth mentioning i just installed caliper covers. Ive checked and double checked the brackets clearance. I bent them a little more because one seems to not have enough. I also bent the dust cover slightly back. Havent heard it today so hopefully its gone. Will keep you updated ??
Old 02-14-2018, 07:15 AM   #4
jkeaton's Avatar
Pull off the wheel and inspect.......
03 GT Convertible, 5-speed
07 V6 Coupe
jkeaton is offline   Reply With Quote
Old 02-14-2018, 11:00 AM   #5
Update: still making the noise. No idea what it could be. It never does it when i turn left
Old 02-14-2018, 11:06 AM   #6
Done this a few times. Anything specific to check for?
Old 02-14-2018, 11:52 AM   #7
Take off both front caliper covers and see if the noise is still there.
FYI:
Those things are not the best for heat dissipation. Be careful if you use your brakes hard repeatedly with those covers on —- the brakes will overheat on many types of cars even without them......
Old 02-14-2018, 12:44 PM   #8
jkeaton's Avatar
This ^^.....chances are, if it didn't make the sound before and now it does, common sense would suggest that maybe they are the culprit......
07 V6 Coupe
Old 02-14-2018, 01:43 PM   #9
Strange Mud's Avatar
Are the calipers rubbing your wheels? That will self correct given enough time
Old 02-14-2018, 02:37 PM   #10
I installed them a week ago and it just started a day or two ago. Im planning on taking them off and trying. But i guess i will have to return them? I dont know how i would ?fix? them
Old 02-14-2018, 02:42 PM   #11
jkeaton's Avatar
Just paint your calipers.
I would also check those dust covers you bent back. Maybe one is bent too far or something.
07 V6 Coupe
Old 02-14-2018, 03:04 PM   #12
Hope its just the covers. Thats an easy fix
Old 02-14-2018, 04:37 PM   #13
you should be able to replicate it with the car jacked up...Use Jack Stands!!!
Old 02-14-2018, 06:58 PM   #14
My 2013 V6 coupe does the same exact thing once I put caliber covers on. I also installed the spacers that are suppose to prevent such from happening but obviously did not make a difference. On a different note, someone replied about just painting the original calipers - does anyone have a recommendation to the best brand of paint to use? I was thinking about removing the caliper covers and painting mine instead.
rgwest61 is offline   Reply With Quote
Old 02-14-2018, 07:51 PM   #15
Beviking's Avatar
Food for thought...the mounting clip is essentially C shaped and fits over the Caliper. The bolt that is on the cover attaches at the top of the ?c? clip. If you over tighten the nut, it could warp the top of the ?c? clip, causing it to spread (because they aren?t perfectly formed to the shape of the Caliper) which puts the bottom 1/2 of the c clip that much closer to the rotor. Add a little heat, metal expands and it will scrape if the rotor has The slightest amount of play, warping or not perfectly in round.
I had the same issue, ground a slight bevel on the bottom edge of the ?c? clip and loosened the nuts and no more scraping. If you have the Caliper off, you could try crimping the clip to form fit onto the Caliper better. That might help.
I personally think stock calipers are ugly, painted or not and the covers make it look cleaner. They also seem to keep the wheels cleaner too. The comment about inhibiting heat dissipation makes sense so I would heed that advice.
Good luck with it!
'12GT Premium, Roush TVS & BAP, VMP Elbow, 82mm, JLT CAI & Catch Can, Eiback Sports, Steeda Cambers & Adj UCA, Adj panhard & Brace, LCAs+Relos, Diff Bushing, Ford Diff Cover, Axle Catch Can, 3.73, Shaftmasters DS, MGW, BG Syncro II, Blowfish Shifter Support Bracket, Trans Mount Insert, MBRP 3" H pipe, Borla 3" Touring Pipes/Axlebacks, High Flow GT Grill Insert, Steeda Spyder Wheels (20X9.5/11), 275 fronts, 315 rears, Lakewood drag shocks, Cervini Hood, big smile
Beviking is offline   Reply With Quote
Old 02-14-2018, 09:06 PM   #16
Good luck with it!
Well i took the front right caliper cover off (thats where the noise is coming from) still same noise. WTF
Old 02-15-2018, 07:05 AM   #17
jkeaton's Avatar
Spin the wheel and isolate it....you have the car in front of you. I go back to whatever you bent to make something fit.
07 V6 Coupe
Old 02-15-2018, 07:11 AM   #18
fender liner?
Old 02-15-2018, 10:48 AM   #19
Well i found it. Rear caliper cover. I feel like an idiot LOL
Old 02-15-2018, 08:31 PM   #20
You have good company here. Glad you found it.two
Old 02-16-2018, 06:19 PM   #21
Beviking's Avatar
You have good company here. Glad you found it.two[IMG class=inlineimg]http://www.mustangevolution.com/forum/images/smilies/new/thumb.gif[/IMG][IMG class=inlineimg]http://www.mustangevolution.com/forum/images/smilies/new/thumb.gif[/IMG]
I resemble that remark! Glad you found it!
Old 02-17-2018, 10:03 PM   #22
I'd remove them all TBTH. They don't do anything except possibly create issues. If you want your calipers to look good pull them off and send them out to get powdercoated, or just paint them.
Lifter tick and scraping metal sound among other things Cmccully Pre-2005 V6 Mustang 0 01-08-2015 11:04 AM
no sound coming from my mach 460 stacy Mustang Audio & Video 2 04-10-2014 11:27 AM
HELP!!! Whistling sound coming from the front/ engine making a clicking sound. Whitestang23 2005-2010 V6 Mustang 5 07-03-2013 05:36 PM
2000 mustang making scraping sound on the back passenger side? kippar 1996-2004 Mustang GT 0 12-14-2011 04:30 PM
Clunking sound coming from rear?? ricklmesa Pre-2005 V6 Mustang 6 11-14-2006 10:36 PM
03:37 AM
