Adjusting 2011 Parking Brake - Mustang Evolution
Old 03-18-2018, 05:16 AM   #1
Hi all I’ve been searching for any tutorials in adjusting the parking brake for the 2011 Mustang GT. Can’t seem to find anything.
My brake pulls all the way up but the car will still drift. I know I can put it in gear but if I want to idle the manual in neutral I can’t since it drifts.
I seen a video where you go into the hand break area but is there an adjustment that is made at the calipers or cable under the car itself?
I use the hand break every time I stop the car and was told it self adjusts but doesn’t seem to?
Any suggestions and or links to tackle this?
Thanks
spankey is offline   Reply With Quote
Old 03-18-2018, 06:37 AM   #2
oxfordwhite's Avatar
Open your console lid and inside you'll find a rectangle shaped access plug that will pop out. This gives you access to the adjustment point of the e-brake cable. Go to you tube and you will find many helpful tips on how to tighten the cable. Very easy to over tighten your e-brake so as to have it drag. Go easy. You can always tighten it more if you think you want more. Happy Trails.
oxfordwhite is offline   Reply With Quote
Old 04-01-2018, 12:32 PM   #3
Repeted pulls on the lever, can sometimes help the self adjusting mechanism move again in the rear brakes. It's common that it seizes. Otherwise adjust with care from the console
Mygind is offline   Reply With Quote
Auto adjusting rear brake calipers question FordMustang12 2005-2010 V6 Mustang 7 05-20-2017 06:18 AM
adjusting the parking brake cable i973eat1 1996-2004 Mustang GT 3 12-25-2014 03:16 PM
Slapped from my E-brake/Parking Brake SunsetGoldGT 2005-2010 Mustang GT 2 05-28-2014 01:45 PM
Parking brake TylerHo1313 Pre-2005 V6 Mustang 1 01-08-2014 12:01 PM
Parking Brake XSlashDashX 1996-2004 Mustang GT 4 06-01-2013 11:12 AM
01:58 AM
