overheating - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs || Tech and Talk > 2.3 Mustang
Old 05-05-2011, 10:03 AM   #1
overheating
Help my 93 lx keeps getting hot. I've changed the thermostat and the thermostat housing. Any clues as to what else may be causing this to happen
acorbin99 is offline   Reply With Quote
Old 05-05-2011, 10:06 AM   #2
USAF_stang's Avatar
Re: overheating
leak in the radiator or hoses?
USAF_stang is offline   Reply With Quote
Old 05-05-2011, 10:07 AM   #3
WildBill's Avatar
Re: overheating
Dude
There are SOOOOOO many things that could cause that!
What changes have you made and when does this occur. If you want a good answer, be VERY thorough with your answer.
WildBill is offline   Reply With Quote
Old 05-05-2011, 10:11 AM   #4
Re: overheating
how old is the radiator? could be clogged up, also is the fan working or going on/off etc, i assume its the fan on the belt drive right so it wont be that?
Old 05-05-2011, 10:16 AM   #5
I haven't made any other changes except from the new thermostat and housing and its not a leak in the hoses. The Guy at the parts store said it may be an airbuble in the system. He said to drain it so I'm in the process of draining the system and refilling it. If this isn't the problem I have no idea what it could be. My water pump is working fine because I've got the pressure on the top and bottom hoses
Old 05-05-2011, 10:18 AM   #6
Its the original radiator
Old 05-05-2011, 11:04 AM   #7
WildBill's Avatar
Re: overheating
Air bubble? Naaaaaa........not in a 2.3.
Draining it wouldn't solve that LOL!
Things to look at:
Clogged radiator................it is original!
Fan functions............shroud still there.
Head gasket leak.
Timing belt.........could have jumped a few teeth
Old 05-05-2011, 11:24 AM   #8
I'm getting a new radiator tomorrow to see if that's the problem
what is shroud?
Old 05-05-2011, 11:25 AM   #9
Re: overheating
it could be air in the system as well~ need to "burp" it good before you install something thats not needed, but a radiator should be replaced every 10 years~
Old 05-05-2011, 11:32 AM   #10
WildBill's Avatar
Re: overheating
A 2.3 doesn't really have air bubble problems like a dang mod motor.
All you need to do with a 2.3 is fill the system, wait for the stat to open, runt it for a few min while adding a bit of coolant, shut off and let cool, then top off to the proper level when cool.
Old 05-05-2011, 11:49 AM   #11
Thanks for all the help. Especially you wildbill. Ill post tomorrow to update on the status of the car
Old 05-05-2011, 11:50 AM   #12
Re: overheating
thanks for the info, good to know
Old 05-05-2011, 01:53 PM   #13
WildBill's Avatar
Re: overheating
Just trying to help.
car overheating AGAIN!!!! Senorjizzy Pre-2005 V6 Mustang 4 09-01-2009 08:04 AM
Overheating 06 probchld1953 2005-2010 Mustang GT 7 06-10-2008 07:25 AM
Overheating problem? Fast93Coupe 1979-1995 Mustang GT 1 07-01-2006 12:29 PM
Overheating problem NorwegianMustang Pre-2005 V6 Mustang 7 04-27-2005 02:52 PM
yet, another overheating story. juanmiguel Pre-2005 V6 Mustang 15 01-04-2005 12:10 PM
04:59 AM
