Gutless! - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs || Tech and Talk > 2.3 Mustang
Old 07-15-2011, 07:11 PM   #1
Hons67's Avatar
Gutless!
Just trying to figure out what might be making my little 2.3l so powerless. I had a thread on here about the tranny not to long ago but I figured out it was shifting funny because someone had put in way to much fluid.
The car shifts smoother now but still has absolutely no power to take off with, even just out of the drive way. I've changed out all the plugs and the cap and rotor but it didn't make any difference.
Just wondering if anyone on here had any ideas what it might be.
Hons67 is offline   Reply With Quote
Old 07-16-2011, 10:33 AM   #2
wereKEV's Avatar
Re: Gutless!
maybe your tranny is slipping it could need a rebuild.
wereKEV is offline   Reply With Quote
Old 07-18-2011, 10:22 AM   #3
Titus Wadicus
svtlx's Avatar
Re: Gutless!
how about the cat? could it be clogged?
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
11:15 PM
