swap cost - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs || Tech and Talk > 2.3 Mustang
Old 11-17-2011, 01:22 PM   #1
footiie's Avatar
swap cost
How much should i expect to pay in labor to replace my blown 2.3 with another 2.3 or 2.3 turbo? Assuming i buy the engine or turbo engine harness and computer. I feel i can get a 2.3 turbo setup for like 6-700$? But how much would a mechanic charge to take out old one and put in new one?
footiie is offline   Reply With Quote
Old 11-18-2011, 02:31 AM   #2
93stang's Avatar
Well if u can find just another 2.3 motor and put it in maybe 100-300. If u do a 2.3 build non turbo about 2000 if u do all the work yourself maybe 1500.
93stang is offline   Reply With Quote
Old 11-18-2011, 02:35 AM   #3
footiie's Avatar
I found a 2.3n/a motor to swap in and moneys tight so id like to try it myself. My first engine swap though so would i be able to pull it off?
Old 11-18-2011, 02:42 AM   #4
93stang's Avatar
Yea u should I would deff find a friend or 2 to come over and help. I would deff suggest takin the head off and doing a inspection on cyl walls. Also check the bottom end out head and check for visiable creaks. Head gasket kit will run about 50-60 that comes with upper lower intake gaskets valve cover gasket and some other one. Trust me I bough a motor from a guy off line and the head gasket was blown. U will save yourself time and hassle if u do it all before u drop motor in.
Old 11-18-2011, 02:47 AM   #5
footiie's Avatar
Thank you for all the advice. Do you mind if i check in with you as i go?
Old 11-18-2011, 02:49 AM   #6
93stang's Avatar
Yes that's fine. Good luck with it
Old 11-18-2011, 03:00 AM   #7
footiie's Avatar
Cool. Thanks!
Old 11-22-2011, 10:18 PM   #8
2300turboford's Avatar
My 2.3 turbo car should make 350 rwhp. Car needs paint and a tune
Old 11-29-2011, 12:28 AM   #9
mustangg2000's Avatar
Region: Arkansas
What all u have done to get that kinda power?
mustangg2000 is offline   Reply With Quote
Old 11-29-2011, 05:32 AM   #10
I ported the head 5 angle valve job bigger turbo injectors and fuel pump header. Down pipe and excaust and huge iner cooler new upper intake ported lower intake and some more stuff I just can't think right now lol dreding school. Lol. I'm 15
Engine swap 96 stang 1996-2004 Mustang GT 8 09-19-2011 07:56 AM
irs to sra swap Black99Snake SVT Mustang 4 08-23-2011 10:41 PM
Pi engine swap Kurlywhiteboy 1996-2004 Mustang GT 0 08-14-2011 10:48 PM
Auto to Manual swap? BrKu789 1996-2004 Mustang GT 9 07-17-2011 10:17 PM
No more engine swap Mustanglife General Mustang Discussion 4 07-07-2011 11:16 AM
11:43 AM
