Shift issues - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs || Tech and Talk > 2.3 Mustang
Old 01-28-2012, 10:02 PM   #1
Loudmustang's Avatar
Shift issues
I bought a 93 2.3L notch auto last week, it's been setting for a while. It runs awesome but the tranny doesn't want to shift while driving. You have to feather the gas to get it to up shift. It down shifts fine when you get on it. It is almost like it hangs between gears reving the engine and finally it will go. Is it in need of a rebuild or could it be a servo on the outside I can change out. I changed the fluid and filter today with no help. Any input is appreciated
Loudmustang is offline   Reply With Quote
Old 01-29-2012, 04:28 AM   #2
Bria1946's Avatar
Re: Shift issues
Sounds like blown/old syncros. Your tranny needs to be rebuilt.
Bria1946 is offline   Reply With Quote
Old 01-29-2012, 02:02 PM   #3
I was afraid of that. I've decided to put in a 5 speed. Thanks
Old 01-29-2012, 04:44 PM   #4
Bria1946's Avatar
Re: Shift issues
5-Speed? Make sure that the 5-speed you select will mate exactly to your bell housing, Etc. At the same time I suggest that you also R & R the Clutch, throw-out-bearing, pressure plate and rear oil seal.
Old 01-29-2012, 09:34 PM   #5
Can I use a T5 out of a v8 car? I did a 5.0 conversion a few years ago so I'm aware of most of the interchangeable parts but I'm insure of the tranny.
Old 01-29-2012, 10:23 PM   #6
Bily Pepp's Avatar
I have an 89 2.3, can I swap it to a 5.0 motor from a 83??
Bily Pepp is offline   Reply With Quote
Old 01-30-2012, 05:11 AM   #7
It will work same as if you had a 93 5.0 to put in. Not too difficult
Old 01-30-2012, 05:54 AM   #8
Bily Pepp's Avatar
Awesome, this is my first car, let alone mustang. I just want it to roar..
Old 01-30-2012, 07:06 AM   #9
If you are sticking with the carb it will be even easier
Old 01-30-2012, 02:09 PM   #10
Bily Pepp's Avatar
Carb the 4cyl.?
Old 01-30-2012, 02:34 PM   #11
The 83 5.0 has a carburetor. Ford did not start EFI until 86'
Old 01-30-2012, 03:31 PM   #12
Bily Pepp's Avatar
Oh ok
Old 01-30-2012, 05:06 PM   #13
Bria1946's Avatar
Re: Shift issues
I have a 1986 2.3. It is carburated. I don't think that the Mustang was offered with EFI until 1987. Except for the SVO...Maybe!
Interior Issues? Dion11197 2011-2014 Mustang GT 20 12-05-2011 06:55 AM
Misfire issues Ghostedmind Pre-2005 V6 Mustang 1 10-02-2011 12:52 AM
2011+ 5.0, lets have a poll on issues DDTCM 2011-2014 Mustang GT 36 09-14-2011 05:56 AM
Black Shift Knob skyline247 2011-2014 Mustang GT 13 09-07-2011 11:06 AM
Shift knob problem with steeda tri-ax apex32 2011-2014 Mustang GT 5 06-29-2011 01:04 PM
02:03 AM
