Thinking about putting one one my mustang but not sure if its worth it? Can you tell a difference in horsepower? How much would it cost?
That would be very helpful93mstnglx said:Or i can give you my build list for the one i custom made
Ok I will find it and post it2.3Foxbody said:That would be very helpful
You might be able to find one online somewhere but I've heard of and seen people use a Rubbermaid plastic 5 gallon trash can and cutting it to fit, or you could get some sheet metal and make one2.3Foxbody said:My dad said something about a box to put around the filter so it's not pulling the heat from the engine. Where would I get one?
I'm guessing it'll make more HP if I have a box?93mstnglx said:You might be able to find one online somewhere but I've heard of and seen people use a Rubbermaid plastic 5 gallon trash can and cutting it to fit, or you could get some sheet metal and make one
Yeah a little bit because the air is cooler than without, mine doesn't have a box yet :/ I'll probably spend the $4 or $5 on a Rubbermaid and try it and if I do I'll le y'all know how it works2.3Foxbody said:I'm guessing it'll make more HP if I have a box?
Just don't go thru deep water or a puddle! LolitsA4cylBro said:My 88 has one going all the way down getting all the cold/fresh air
Alright! Do you know of any other way to get more HP?93mstnglx said:Yeah a little bit because the air is cooler than without, mine doesn't have a box yet :/ I'll probably spend the $4 or $5 on a Rubbermaid and try it and if I do I'll le y'all know how it works
Just so you know I'm only 17 and don't understand some of this. HahaitsA4cylBro said:Remove your cats . Get a magnaflow muffler sounds mean. Get some lightweight pulleys just not the crankone .
---------- Post added at 10:33 PM ---------- Previous post was at 10:32 PM ----------
Just make your cat removal bolt on so when u need to pass smog . Oh and use 91 gas
The catalytic converters are the big oval shaped things, one you can see from under the hood and the other one is under the car, and the pulleys are what tour belts run on and he forgot a space between crank and one, so light pulleys other than the crank pulley and smog is the emissions control stuff some states randomly check vehicles to make sure they have the proper equipment. (I don't know what you don't know that's why I covered all of it )2.3Foxbody said:Just so you know I'm only 17 and don't understand some of this. Haha
19 as of last monthitsA4cylBro said:How old are you anyway? I'm 21
I personally would go with regular liftersitsA4cylBro said:What would your prefer for the cams hydraulic lifters or regular
I'm honestly not sure I'd have to research thatitsA4cylBro said:Don't your 91-93 come with hydraulic?
