I am trying to put a F2 ProCharger on a 67 Mustang, can I make it fit? - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs || Tech and Talk > 2.3 Mustang
Old 03-06-2010, 06:15 PM   #1
I have a 331 stroker motor SVO R-Block, 185afr heads, hydraulic rotor cam. I am trying to make it two tunings, one 91 Octane, and the other one race gas. Is it possible?
This motor was making 570hp with a vortech w/9psi boost.
Just like that would it be possible to make over 800hp with this F2?
sein is offline   Reply With Quote
Old 03-06-2010, 07:12 PM   #2
Here's a Novi 1200 on a 67-68 from Paxton.
http://store.summitracing.com/partde...5&autoview=sku
But... a couple of things concern me about the validity of your question:
1. What is an "SVO R-Block"? I've seen "A4" blocks from FRPP, and even those would split in half at 800hp.
2. What is a "hydraulic rotor cam"?
3. "Two tunings"? Does this 67 have EFI?
4. Only more boost will change the amount of hp in a super charger swap.
If you don't have subframe connectors and/or a 'cage, it won't matter anyway, your Mustang will look like a pretzel.
cingeswiella is offline   Reply With Quote
Old 03-06-2010, 07:40 PM   #3
you can do it with the right computer program, the SVO used a switch to go from premium to regular.boost settings..
taurino is offline   Reply With Quote
06:42 AM
