Why does my 1979 Mustang burn oil in high rpms? - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs || Tech and Talk > 2.3 Mustang
Old 12-23-2011, 10:15 PM   #1
Simple as that. Its the 2.3l non-turbo version, but when I accelerate "fast" (turtles are fast too!) it burns oil. I'm thinking its something to do with old rings/seals around the cylinders and then oil blows by. Anyone have an idea? and how to fix it?
kinsella is offline   Reply With Quote
Old 12-23-2011, 11:09 PM   #2
Well the only 2 possibilities are valve guides or piston rings, and the way to tell is with a compression test. You can repeat the test with a table spoon of oil in each cylinder, and if it improves, then it is the rings and not the guides. Guides are a lot easier to do, because you only have to take the head off.
For rings you really need a whole rebuild.
However, it is possible the rings are just carboned in and sticking, but I don't know a good way to clean them.
All I can suggest is switching to Castrol 20w-50 oil, and frequent changes to clean it out.
camdin is offline   Reply With Quote
Old 12-24-2011, 12:07 AM   #3
The rings and/or valve guides are worn out.
Orbart is offline   Reply With Quote
Old 12-24-2011, 12:27 AM   #4
Jem
Could have ring trouble but check all of the PCV system to see if it is blocked or somehow bad. This can blow oil into the air filter box then the engine ingests and burns it with the air/fuel. More throttle, more pressure, more oil, more smoke.
Jem is offline   Reply With Quote
Old 12-24-2011, 01:04 AM   #5
repair engine, or make sure pcv valve works and has vac. Use proper oil, 15W40 motorcraft oil
makis is offline   Reply With Quote
1979 mustang
04:41 AM
