what do i need for an auto to manual swap? - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs || Tech and Talk > 2.3 Mustang
Old 01-29-2013, 11:05 PM   #1
itsA4cylBro's Avatar
Besides the tranny of course but what is needed for this swap . I have. Job now and considering putting a t5 in it and gettin turbo . Info and details please if you know
itsA4cylBro is offline   Reply With Quote
Old 01-30-2013, 11:24 AM   #2
Beatjunkiexorge's Avatar
Just mind as well buy a new car SVO , it's cheaper
Beatjunkiexorge is offline   Reply With Quote
Old 01-30-2013, 01:48 PM   #3
Theres nothing that I see . I only see manual to auto
Old 01-30-2013, 07:01 PM   #4
**notice**
Please stop the bickering or the thread will be closed and infractions will be issued. The search feature is a great tool when it actually works. I do recommend using it, but anyone is entitled to have there own thread.
Old 01-30-2013, 09:59 PM   #5
Justasix98's Avatar
Honestly.. It would be a lot easier and cheaper to have the auto built, put in a shift kit, maybe a small stall. A lot of people do prefer manuals such as myself but in your case having the auto built would be the way to go. It'll also save you a lot of time and money in the long run.
Just A Sixxer!
Proud member of WickedStangs Okc Chapter!
Justasix98 is offline   Reply With Quote
Old 02-04-2013, 01:43 PM   #6
rbohm's Avatar
swapping a T5 in place of an auto trans can be done with factory parts. first find a T5 bell housing for the 2.3 motor. that is the hardest part. after that it is just collecting all the little parts and pieces, like a clutch pedal, clutch cable, flywheel, clutch system, etc. since you plan on turboing the motor, i suggest stepping up to a V8 T5 as they are much stronger than the 4 or six cylinder versions, they just dont have the deep first gear the four cylinder version does, no biggie though, just run a bit more rear gear, IE a 4.10 gear instead of a 3.73.
my mind is aglow with whirling transient nodes of thought careening through a cosmic vapor of invention.
rbohm is offline   Reply With Quote
Old 02-04-2013, 11:55 PM   #7
Thanks for the info. U know about the svo diff fitting in the n/a since they both 7.5
Old 02-05-2013, 07:26 PM   #8
rbohm's Avatar
as long as you are getting parts for the rear axle you have, they all fit.
Old 02-06-2013, 01:22 AM   #9
Do you know how to remove the gears?
Old 02-06-2013, 01:30 PM   #10
rbohm's Avatar
once you pull the rear cover, you will see a total of four bolts holding in two large caps. remove the axles and the bolts and the carrier drops out of the housing. the pinion gear must be pressed out. you them unbolt the ring gear from the differential. if you havent done this kind of work before, it is best left to the pros as there are tools you need when putting things back together again, that most people dont have.
Old 02-06-2013, 07:17 PM   #11
How much do they usually charge?
Old 02-09-2013, 01:10 PM   #12
rbohm's Avatar
to be honest i dont know, but figure at least $250 for labor these days.
Old 02-09-2013, 02:04 PM   #13
Tooo ooo much. Might as well do this myself .
Old 02-09-2013, 04:53 PM   #14
rbohm's Avatar
only you can decide for yourself, but if you do it yourself to save on the labor, and get the adjustments wrong and ruin a good ring and pinion set, you are on the hook for a new set, and they are not cheap. best to call around first and get a quote for how much it would cost to have a shop install the new gears for you.
Old 02-09-2013, 06:57 PM   #15
Haha I know. My bro graduated from uti he's helpingme
10:42 AM
