oil pump bad :(( - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs || Tech and Talk > 2.3 Mustang
Old 01-30-2013, 10:57 PM   #1
itsA4cylBro's Avatar
oil pump bad :((
I started to hear my lifters loud like its gasping for oil at very low idle. Now I left it without turning on for almost a week and turn it on and here it loud! Then went away after 3 sec being on . I'm pretty sure its my oil pump . Its never been changed . Should've changed it when I had the engine out. But **** it I guess either I pull the whole thing out again or I just lift it enough to get the pan off and pump . What you guys think about this situation
---------- Post added at 09:57 PM ---------- Previous post was at 09:55 PM ----------
Oh and forgot to add that my oil level was fine too
itsA4cylBro is offline   Reply With Quote
Old 02-01-2013, 08:12 PM   #2
I would install an aftermarket oil pressure gauge first to see what you have before going through the trouble of changing the pump.
Old 02-02-2013, 12:04 AM   #3
What should it be at normally?
Old 02-02-2013, 03:58 AM   #4
10 psi for every 1k rpm.
Old 02-02-2013, 08:40 AM   #5
K thx . Hey btw do you guys know if the posi unit from the svo will fit on my rear end. We should have a 7.5 also. I seen someone on craigslist has one for sale with the gear too
Old 02-02-2013, 09:43 AM   #6
Lorraine's driver
ab_mach1's Avatar
The whole rear diff, or just the inside? Correct me if I'm wrong guys. The traction-Lok is an 8.8 and should bolt on any fox.
Instagram: @ab_mach1
Old 02-02-2013, 10:07 AM   #7
No svo is 7.5
---------- Post added at 09:07 AM ---------- Previous post was at 09:06 AM ----------
And well yes excluding axles .
Old 02-02-2013, 11:40 AM   #8
Lorraine's driver
ab_mach1's Avatar
No svo is 7.5
Cool, I didn't know they also had a traction-Lok 7.5 too. I don't see why your pumpkin wouldn't work as they are the same in size.
Old 02-03-2013, 02:09 PM   #9
Foxtrot's Avatar
If you are going to replace the axle I would just find an 8.8" rearend. It can take a beating and you will also have a lot more parts available
Foxtrot is offline   Reply With Quote
Old 02-03-2013, 06:14 PM   #10
Yeah but I have automatic tranny a4ld . Isnt the driveshaft different lengths
03:30 AM
