02-10-2013, 02:44 PM
#1 | | Registered User
| Gas smell after full tank of gas
Hey guys, I just put a full tank of regular pump gas in my 2.3 and after sitting overnight I'm smelling gas. I'm wondering if any one else has or had this problem before or can keep me figure out why it's happening. Thanks
Megan the Fox
1993 Mustang LX
2.3l 105+ hp. 4cyl.
Custom made Cold air intake
Plasti-Dipped stock 10 hole wheels
02-10-2013, 03:00 PM
#2 | | Registered User
I forgot to mention I don't put a full tank in all the time
Megan the Fox
1993 Mustang LX
2.3l 105+ hp. 4cyl.
02-10-2013, 03:33 PM
#3 | | Registered User
Ok it seems to be an overfilled tank, I think, there is some gas residue on the back of the tank and a couple of spots in. the ground where she was sitting
Megan the Fox
1993 Mustang LX
2.3l 105+ hp. 4cyl.
02-10-2013, 04:36 PM
#4 | | Registered User
looks like you answered your own question |
02-10-2013, 05:35 PM
#5 | | Registered User
| Quote:
Originally Posted by alrefire looks like you answered your own question  | Yeah I kind of did lol : p
Megan the Fox
1993 Mustang LX
2.3l 105+ hp. 4cyl.
02-10-2013, 10:05 PM
#6 | | Registered User
it sounds to me like the hose between the filler neck and the tank is leaking. its time to replace it.
my mind is aglow with whirling transient nodes of thought careening through a cosmic vapor of invention.
02-10-2013, 10:51 PM
#7 | | Registered User
| Quote: |
Originally Posted by rbohm it sounds to me like the hose between the filler neck and the tank is leaking. its time to replace it. | When I was looking at it earlier it looked that way , thanks
Megan the Fox
1993 Mustang LX
2.3l 105+ hp. 4cyl.
02-11-2013, 08:01 AM
#8 | | Registered User
There's also a gas evaporation valve on top with a hose and a seal. That seal always seems to rot on most cars my rotted big time so gas kept spilling everytime I turned and just walking by I smelled gas. Sucky thing about that seal is that its dealer item only
02-11-2013, 08:03 AM
#9 | | Registered User
| Quote:
Originally Posted by itsA4cylBro There's also a gas evaporation valve on top with a hose and a seal. That seal always seems to rot on most cars my rotted big time so gas kept spilling everytime I turned and just walking by I smelled gas. Sucky thing about that seal is that its dealer item only | Seriously?? How hard was it to fix?
Megan the Fox
1993 Mustang LX
2.3l 105+ hp. 4cyl.
02-11-2013, 08:13 AM
#10 | | Registered User
U have to drop the tank down to fix it. The seal was easy to install but putting that valve in with the new seal without breaking the valve was so ****in hard . But managed with some big time screaming hahah . U should replace the seals all up there and the neck ones too while its down unless u wanna keep dropping the gas tank like I did because fuel pump went out fixed it then the fuel pump hose went out fixed it then the freaken valve I was mad by that time dropping the gas tank so many times. But its up to you lol. Two times were when bye gas tank was filled more then half way that **** was heavy .the last time it was almost empty . But a Jack and a flat piece of wood should help you a lot
02-11-2013, 09:30 AM
#11 | | Registered User
| Quote:
Originally Posted by itsA4cylBro U have to drop the tank down to fix it. The seal was easy to install but putting that valve in with the new seal without breaking the valve was so ****in hard . But managed with some big time screaming hahah . U should replace the seals all up there and the neck ones too while its down unless u wanna keep dropping the gas tank like I did because fuel pump went out fixed it then the fuel pump hose went out fixed it then the freaken valve I was mad by that time dropping the gas tank so many times. But its up to you lol. Two times were when bye gas tank was filled more then half way that **** was heavy .the last time it was almost empty . But a Jack and a flat piece of wood should help you a lot | What did the seal run you on price?
Megan the Fox
1993 Mustang LX
2.3l 105+ hp. 4cyl.
02-11-2013, 10:04 AM
#12 | | Registered User
$10-15
02-11-2013, 10:08 AM
#13 | | Registered User
| Quote:
Originally Posted by itsA4cylBro $10-15 | OK cool thanks!
Megan the Fox
1993 Mustang LX
2.3l 105+ hp. 4cyl.
02-11-2013, 10:47 AM
#14 | | Registered User
Yeah good luck !
02-11-2013, 11:13 AM
#15 | | Registered User
The grommet/seal thing just busted on my Cobra a few weeks ago. Me and my dad replaced it. It was causing the same thing as your talking about.
'01 Cobra
Forged Internals, Limited Slip Differential, 3:73s, Bama Tune, Pro 5.0 Short Shifter, Mach 1 Air Intake, 31 Spline Moser Axles. |
02-11-2013, 09:37 PM
#16 | | Registered User
| Quote:
Originally Posted by 98StangKid The grommet/seal thing just busted on my Cobra a few weeks ago. Me and my dad replaced it. It was causing the same thing as your talking about. | |
