4 lbs of boost - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs || Tech and Talk > 2.3 Mustang
Old 02-11-2013, 07:14 PM   #1
Mr.5.0's Avatar
Region: New Mexico
4 lbs of boost
I hooked up my boost gauge and on the hardest pull it only boosted 4 lbs and it's a stock block I need to bump up the boost does anybody have any advice
Mr.5.0 is offline   Reply With Quote
Old 02-14-2013, 07:43 PM   #2
rbohm's Avatar
are you using a blow off valve or a waste gate? either way you need to up the spring pressure that controls the valve to gain boost pressure. some are adjustable, some are not and you need to replace the spring.
my mind is aglow with whirling transient nodes of thought careening through a cosmic vapor of invention.
rbohm is offline   Reply With Quote
Old 02-19-2013, 12:10 PM   #3
2300turboford's Avatar
i think you car has a internal waste gate u will have to change the spring or buy a tubular header and run a exteral waste gate witch is what i would recemend
04:45 AM
