camshaft - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs || Tech and Talk > 2.3 Mustang
Old 04-04-2013, 09:52 AM   #1
martin 16's Avatar
camshaft
I want to change the camshaft on mustang 2.3 year1979
What other pieces i need change in valve train
martin 16 is offline   Reply With Quote
Old 04-06-2013, 12:14 PM   #2
AgentOrange's Avatar
Source a roller cam from a Ranger. Should be able to swap just the cam and roller followers. Read up on it a little.
AgentOrange is offline   Reply With Quote
Old 04-06-2013, 12:31 PM   #3
2300turboford's Avatar
If u get a boport it other aftermarket cam u need better valve springs and if u convert to roller ull need lifters and rockers
Old 04-06-2013, 11:20 PM   #4
then port the intke like a mofo. you can make these little guys scream!!!!! cams are so cool.
mustanghick is offline   Reply With Quote
Old 04-08-2013, 12:47 AM   #5
itsA4cylBro's Avatar
Do you guys recommend the 120 or 130 degree intake manifold? I'm thinking of buying one if not modding mine to it. I Seen em on ebay for $250 ported to the max and whatever angle you want
itsA4cylBro is offline   Reply With Quote
Old 04-08-2013, 06:38 AM   #6
Are you running a front mount intercooler? Only reason to rotate the intake is for routing of IC. I wouldn't bother porting unless you get head work done as well.
Old 04-08-2013, 07:08 AM   #7
Well I'm planning on the turbo with a front mount intercooler also with sn95 tb
Old 04-08-2013, 07:23 AM   #8
Just depends on how you want that FMIC piped. If you don't mind the long pipe across your engine bay you don't need to rotate. If you want both pipes facing directly forward and it's worth the money then get a ported and rotated piece.
07:19 PM
