Stang Trouble - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs || Tech and Talk > 2.3 Mustang
Old 04-10-2013, 08:24 PM   #1
MSTNGLX1's Avatar
Stang Trouble
My 2.3L automatic is giving me trouble. Sometimes I turn it on and it begins to shake, the rpm's begin to drop and it turns off. I have to press the gas to keep it from turning off on me. When im at a stop sign or red light I have to press the brakes and the gas at the same time to keep it from turning off. Does anyone know what's wrong with it? Is it the throttle body.
MSTNGLX1 is offline   Reply With Quote
Old 04-10-2013, 09:13 PM   #2
5litereater's Avatar
Maf sensor? Does your stang have one?
5litereater is offline   Reply With Quote
Old 04-10-2013, 09:15 PM   #3
1lowGT's Avatar
Most likely not the throttle body. When you rev it does it seem so have a loss of power? Sputter out when you rev? Any sign of misfire?
Old 04-10-2013, 09:16 PM   #4
It may also be your fuel filter
Old 04-10-2013, 09:52 PM   #5
MSTNGLX1's Avatar
I replaced the fuel pump and filter. I think it might be the maf.
Old 04-11-2013, 07:47 AM   #6
itsA4cylBro's Avatar
Check out your alternator . Probably not charging at low rpm
itsA4cylBro is offline   Reply With Quote
Old 04-11-2013, 09:23 AM   #7
MSTNGLX1's Avatar
This morning I turned it on and it was fine. I waited 5 min, the rpm's lowered and rose but the car didn't turn off. As soon as I put it into drive and the rpm's lowered, it began shacking and it turned off. And now it wont start.
Old 04-11-2013, 09:53 AM   #8
1lowGT's Avatar
That dont seem like maf
Old 04-11-2013, 12:47 PM   #9
MSTNGLX1's Avatar
When I was buying this car the owner told me that he had only changed the sensors but, he didnt tell me which ones
Old 04-13-2013, 10:44 PM   #10
Maybe a crank shaft positioning sensor?
Old 04-13-2013, 10:54 PM   #11
MSTNGLX1's Avatar
I got a new maf sensor and its working better.
---------- Post added at 11:54 PM ---------- Previous post was at 11:50 PM ----------
Does anyone know what size pistons, fuel injectors and gears I can put in my 2.3L?
Old 04-14-2013, 12:50 AM   #12
Gears 3.73.
Old 04-14-2013, 12:36 PM   #13
Basically keep your gears . Just throw in a posi diff . Most of our rears lol come stock 3.73 non posi . It should say on the tag in the back what you have. I put my differential from an svo . I took off its 3.45 it had original and put my gear on and bolted right on.
Old 04-14-2013, 09:40 PM   #14
Awesome! Glad it's working better for you
Old 04-14-2013, 10:04 PM   #15
MSTNGLX1's Avatar
Thanks
Old 04-15-2013, 10:17 PM   #16
MSTNGLX1's Avatar
The only trouble I have now is finding a good insurance lol
Old 04-15-2013, 10:26 PM   #17
Auto insurance?
Old 04-27-2013, 08:59 AM   #18
MSTNGLX1's Avatar
My car is still doing the same thing. Sometimes when I'm driving and I'm accelerating it loses power. I have to press the accelerator constantly for it to move. Eventually it becomes normal and drives normaly. What can it be?.. The fuel injectors? I know its not the maf or the intake.
Old 04-28-2013, 09:17 AM   #19
1987mustanglx50's Avatar
Check the idle air control valve if it has one you should also rebuild your torque converter to your transmission I had a problem before with one one of my mustangs doing that I rebuilt the torque converter and it fixed the problem that's what might be wrong with your mustang
1987mustanglx50 is offline   Reply With Quote
08:03 PM
