Running rough and hesitation when accelerating from a stop. - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs || Tech and Talk > 2.3 Mustang
Old 04-24-2013, 01:48 PM   #1
I have a 1991, convertible, 2.3 stock engine. My car runs very rough when first starting and during acceleration. After a few minutes of driving the check engine light will come on and it starts running a lot better but still with some hesitation during acceleration. I have replaced the plugs, wires, both coils, Idle air control valve, throttle position sensor, fuel pump, fuel filter, battery, done an air induction cleaning, and run cleaner thru my gas. I use Shell premium plus gas. The only things left I can think of are the mass air flow sensor, although I did clean it and the engine will run differently when unplugging it while at idle, the fuel injectors, and PCM. Any suggestions??
jacobpytlik is offline   Reply With Quote
Old 06-28-2013, 07:05 PM   #2
5litereater's Avatar
Try changing your ICM? I just did on mine it made a huge difference and maybe the coils as well
---------- Post added at 08:05 PM ---------- Previous post was at 08:04 PM ----------
Forget the coils lol just saw you replaced em
5litereater is offline   Reply With Quote
Old 07-22-2013, 10:50 PM   #3
Also if your car dies when you unplug you Maf the Maf is bad
09:19 PM
