Feathering gas pedal to start - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs || Tech and Talk > 2.3 Mustang
Old 07-16-2013, 08:37 AM   #1
5litereater's Avatar
1993 2.3 n/a I have to turn it over about 3times and it might hiccup. Then I turn it over again a couple times and it starts and hovers around 2k and goes down to about 1100k and sits for about 3.5sec and then dies unless I feather the gas. What do you guys think?
---------- Post added at 08:37 AM ---------- Previous post was at 08:33 AM ----------
And once it warms up its fine. A little hesitation bad not to bad
5litereater is offline   Reply With Quote
Old 07-17-2013, 02:36 AM   #2
itsA4cylBro's Avatar
Check the fuel pressure regulator upper hose make sure its not stuck. Squirting out gas . If it is is clogging everything
itsA4cylBro is offline   Reply With Quote
Old 07-17-2013, 12:36 PM   #3
So it should be squirting guild out of the top nipple?
---------- Post added at 12:36 PM ---------- Previous post was at 12:34 PM ----------
Fluid*
Old 07-17-2013, 11:07 PM   #4
Aha! You were right lol I'm getting the part tomorrow hopefully that fixes it
Old 07-18-2013, 12:10 AM   #5
Yeh it happened to me once bro . Can't believe I found the problem
---------- Post added at 09:10 PM ---------- Previous post was at 09:10 PM ----------
Glad to hear helped you out
Old 07-18-2013, 03:02 PM   #6
Didn't fix it -.- but that was one of the problems so idk what's wrong Dx
Old 07-18-2013, 03:10 PM   #7
So what else would it might be?
Old 07-18-2013, 03:13 PM   #8
Map sensor located on firewall? Make sure hose aint bent or tore
Old 07-18-2013, 03:32 PM   #9
I think I saw a factory cap on it >.> lemme check lol
Old 07-18-2013, 04:14 PM   #10
Check hoses that go in the fenderwell too because they get ripped .
Old 07-20-2013, 07:44 PM   #11
Non are broke and the map sensor looks fine I got the code pulled 334
Old 07-22-2013, 10:48 AM   #12
It nearly stalls under normal acceleration. It does it at about 32-37mph. And then I get this weird smell in the cab >.> idk if this'll help
Old 07-23-2013, 02:50 AM   #13
You clean your maf?
And you have enough oil? Fuel filter clogged? timing off? alternator going bad?
Old 07-23-2013, 12:02 PM   #14
New maf, enough oil, new fuel filter and timing is good.
---------- Post added at 12:02 PM ---------- Previous post was at 12:01 PM ----------
Idk if alternator... Ill get it tested
Old 07-23-2013, 08:33 PM   #15
Leakin gas smell? And umm ur cats may be clogged up and smelling. All the 2.3 mustang cats tend to all clogg up and start smellin and restrict so much performance . Mine was clogged and I changed em to original and car ran beast.
Old 07-23-2013, 08:56 PM   #16
+1
Old 07-23-2013, 08:59 PM   #17
Old 07-23-2013, 09:12 PM   #18
What?
Old 07-23-2013, 09:18 PM   #19
Just wondering what +1 means
Old 07-23-2013, 10:38 PM   #20
That might just be it >.> ill look into that and what? Lol
Old 07-23-2013, 10:39 PM   #21
Basically a quick way to say "I agree"
Old 07-23-2013, 10:50 PM   #22
Ohhh ok lol
Old 07-24-2013, 07:58 PM   #23
I'm just gunna cut the cats and put a magna flow pipe in there
Old 07-24-2013, 08:38 PM   #24
Lol Im gonna make mine a dual muffler magnaflow
---------- Post added at 05:38 PM ---------- Previous post was at 05:37 PM ----------
Dont know if two mufflers is better then one for sound or performance. And gettin it ready for the turbo build
Old 07-25-2013, 07:50 AM   #25
Idk either hmmm
Old 07-25-2013, 10:57 PM   #26
Ok so I cleaned the TB and it runs great! But I went to Walle-world (Walmart) and ran inside to grab something real quick and went back outside and tried to start it up and the mother$@#%er wouldn't start!!!! Sooooooo I had to wait about 30-45min and had to keep pulsing the gas to freaking start it > help please again... This thing is about to get filled with lead
Old 07-31-2013, 08:54 AM   #27
Ok I'm going to get the pipes today hopefully it helps. Should I get Magnaflow or Flowmatsers? I'm thinking about redoing the whole exhaust.
Old 07-31-2013, 12:14 PM   #28
Magnaflow!!! Flowmaster sounds like **** on 4 cyl
Old 07-31-2013, 01:55 PM   #29
I love the sound of thrush welded mufflers on the 4 cylinders
Old 07-31-2013, 10:55 PM   #30
Why how does it sound
Old 08-12-2013, 08:25 PM   #31
So I put them in awesome sound pulls a little better still have to feather the gas pedal though -.- and it still hesitates like a mofo.
Old 08-13-2013, 04:21 AM   #32
Magnaflow? Put a video bro wanna hear sound
---------- Post added at 01:21 AM ---------- Previous post was at 01:20 AM ----------
But a good quality sound though not so close cause then it sounds like crap all static
---------- Post added at 01:21 AM ---------- Previous post was at 01:21 AM ----------
And is ur timing off?
Old 08-15-2013, 10:52 PM   #33
Can't upload a vid -.-
---------- Post added at 10:52 PM ---------- Previous post was at 10:52 PM ----------
And yes magna
Old 08-16-2013, 01:44 PM   #34
Put it on YouTube then send us link bro and which magna did you get
Old 08-17-2013, 04:49 PM   #35
Ok we'll do and I just bought the pipes haven't done the whole system yet
05:43 AM
