Synthetic oil - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs || Tech and Talk > 2.3 Mustang
Old 12-10-2013, 09:47 AM   #1
Doubledeee99's Avatar
Synthetic oil
Ok so I tried to find my answer on Google and other forums and nothing so here is my question.
My best friend bought an 89 lx and we were talking about synthetic oil when Mr. Know-it-all at o'reilys said not to change to synthetic because of the "cork caps" in older cars and you will have an oily mess and blow the motor because of how old it is...then he proceeded to say mustangs don't need synthetic it won't run any better, so my question is, does the 89 lx have cork caps or whatever and will it be ok to change to synthetic?
Doubledeee99 is offline   Reply With Quote
Old 12-10-2013, 11:34 AM   #2
Can someone just say yes or no please?!!!! Helppppp
Old 12-10-2013, 11:38 AM   #3
nhcowboy's Avatar
Maybe...
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 12-10-2013, 11:39 AM   #4
Originally Posted by nhcowboy View Post
Maybe...
-_-
Old 12-10-2013, 11:47 AM   #5
nhcowboy's Avatar
-_-
I've always been hesitant on older cars to switch to full synthetic... Could leak.
Maybe a high mileage blend?
12.538 ET @112.33
Old 12-11-2013, 01:04 AM   #6
I honestly can't say yes or no on that :/ sorry
But I will recommend a high mileage oil, last change I put Castrol gtx high mileage in and she seemed to like it.
Good luck!
Ps I've never heard of "cork caps"
Old 12-11-2013, 04:02 AM   #7
87LX306's Avatar
+1
For sure good oil IMO as well. Have been running it in my own vehicles as well as customer rides. Always looks good when I drain it, still has lubrication left as well. I generally will toss a little Lucas Oil Stab in when im changing the oil. Just make sure you buy a decent filter "no fram".
87LX306 is offline   Reply With Quote
Old 12-11-2013, 05:06 AM   #8
bucko's Avatar
Pure internet nonsense that synthetic will cause an oil leak with older cars. Todays synthetics can even be mixed with non synthetics for safe operation.
If you want to use synthetic or semi synthetic in your engine, do it. If the engine is a high mileage "smoker", then don't waste your money, as the synthetic won't help that of course.
And find another auto parts store. That friendly know it all at your o'reilys is giving out wrong advice when it comes to synthetic oil use.
Old 12-11-2013, 09:54 AM   #9
Originally Posted by 87LX306 View Post
+1
Why no fram?
Old 12-11-2013, 12:43 PM   #10
v8pony's Avatar
Why no fram?
NEVER FRAM...
2002 5spd GT
Feb 2013 Mustang of the Month
Old 12-11-2013, 04:12 PM   #11
87LX306's Avatar
Why no fram?
Junk construction. Goto the store and grab fram ph2 and a motorcraft fl820s. Cut them both open. You tell me.
Old 12-11-2013, 04:13 PM   #12
v8pony's Avatar
+1938373, mucho cardboard in FRAM
2002 5spd GT
Old 12-11-2013, 04:23 PM   #13
87LX306's Avatar
Its not only the cardboard. Has the lowest number of pleats VS any of the others, uneven pleats VS others, junk bypass valves, tin holding the pleats where others are glued.
Frams will typically make less oil pressure VS other brands as well due to poor quality design. Back in the 50's Fram was the bees knees, have been less than stellar for decades.
Old 12-11-2013, 04:30 PM   #14
Thanks for the info! I'll be using a different brand next change
Old 12-12-2013, 12:04 AM   #15
The first synthetic oil that came out back in the mid 1970s were ester based oils and they were bad about causing leaks. The oils that are produced now have a different formulation, just use the correct weight and you should be fine. It's not the old car it's the old oils!
trustyrusty436 is offline   Reply With Quote
Old 12-12-2013, 08:40 PM   #16
I honestly can't say yes or no on that :/ sorry But I will recommend a high mileage oil, last change I put Castrol gtx high mileage in and she seemed to like it. Good luck! Ps I've never heard of "cork caps"
Yeah the "cork caps" I didn't know wtf he was talking about lol
Thanks for all the help and info!!!!!
Old 12-13-2013, 10:27 PM   #17
silverstangboy's Avatar
actually in older cars that smoke synthetic oils do help, they are more resistive to being burned.
I have seen it used on older cars up north to pass inspections testing.
and the cork caps the guy is refering to is cork front and back lower intake to block gasket and the gasket for the valve covers.. but he is still wrong.
93 mustang notch
~450hp 331 stroker - Sold
Old 12-16-2013, 12:51 PM   #18
rbohm's Avatar
all good information. back in teh day when synthetics were first introduced to the public, no one realized that synthetic oils were very aggressive at cleaning out the accumulated junk in an engine. and often times that sludge was plugging oil leaks that already existed. when the sludge was gone, the leak reappeared giving the impression that the oil caused the leaks.
Why no fram?
plus time infinity on trashing fram oil filters and going with a good brand like purolator, motorcraft or wix.
and not just less oil pressure, but more inconsistent oil pressure as well.
my mind is aglow with whirling transient nodes of thought careening through a cosmic vapor of invention.
rbohm is offline   Reply With Quote
08:32 PM
