1989 mustang lx 2.3 electric fan - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs || Tech and Talk > 2.3 Mustang
Old 12-29-2013, 04:40 PM   #1
1987mustanglx50's Avatar
My electric fan won't turn on I check all of the wiring fuses and wired the fan directly to the battery to make sure it works and it did I replaced the cooling fan temperature switch and the coolent temperature sensor as well the fan won't come on unless I turn on the ac and once the clutch to the ac kick in the fan will turn off on its own once it reached the temperature were it normally turns off unless I need to still replace the temperature sending unit I doubt it that though but any help will be much appreciated and thanks in advance
1987mustanglx50 is offline   Reply With Quote
Old 12-29-2013, 04:44 PM   #2
1989 mustang lx 2.3
Name:	1989 mustang lx 2.3L.gif
Old 12-29-2013, 04:50 PM   #3
Unless the cooling fan temperature switch is bad?
Sent from my RM-917_nam_usa_214 using Tapatalk
Old 12-30-2013, 05:59 PM   #4
Did you check the fan relay?
Lord Snow is offline   Reply With Quote
Old 12-30-2013, 06:07 PM   #5
I tried looking for it on demand 5 says its next to the starter relay\solenoid but nothing is their I tried looking for it and nothing I also grounded the wire that goes to the cooling fan temperature switch and the fan does come on so I know the wiring,fuses,relay are ok
Old 12-31-2013, 12:31 PM   #6
From what I read in my Haynes manual, the fan only with the a/c on, I don't get why it would be that way.
My a/c went out on my 93 and the fan stopped working at that point so I finally just wired a switch to the fan so I can turn it on.
Good luck
Old 12-31-2013, 12:33 PM   #7
Yea it is but I will get it thanks for the help though I had it with a switch as well but I want to fix it the right way you know cause as far as i know they both share the same relay the ac and the cooling fan
Old 12-31-2013, 12:53 PM   #8
I totally understand wanting to fix it the right way.
If you find that they DO share the same relay please let me know which it is.
Old 12-31-2013, 02:51 PM   #9
No problem will do
Old 12-31-2013, 03:05 PM   #10
They both do share the same relay
Old 01-01-2014, 12:41 AM   #11
never mind the relay is under the dash
1989 mustang
06:11 PM
