93 lx 2.3 engine mods? - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs || Tech and Talk > 2.3 Mustang
Old 02-28-2014, 05:28 AM   #1
93.400k4cylfox's Avatar
I'm looking to add some power to my little 4cyl. What kind of mods can I do to squeeze more power out of my motor? I've heard I can get a dirt track head internals and header from esslingeracing.com for a street car without any issues. But I'm afraid of the motor overheating or having other major issues as a daily driver with dirt track stuff on it. Any info (other than V8) would be appreciated. Thanks
93.400k4cylfox is offline   Reply With Quote
Old 03-01-2014, 04:42 PM   #2
rbohm's Avatar
all dirt track parts mean is that they are set up for dirt track racing. they still have the stock cooling passages, and work just fine on a street engine. in fact they tend to work better. remember that dirt tracks are short tracks, which means that low end and mid range power is what is needed. and that is also what is needed for the street as well.
the next thing would be to get a ranger cam and install that. after that pull the intake and have it ported, both the upper and lower intake. you can also install a larger throttle body, i think the stock one is 55mm, so an upgrade would be a 60mm throttle body. bump the ignition timing to between 10-14 degree initial, remember to disconnect the spout connector before setting the timing, and remember to reconnect it when you are done. swap the engine driven fan for an electric one.
these are good places to start.
my mind is aglow with whirling transient nodes of thought careening through a cosmic vapor of invention.
rbohm is offline   Reply With Quote
Old 03-01-2014, 08:00 PM   #3
Thanks all good info. My car came with the electric fan though lol.
Help understanding the relationship between flywheels and engine vibrations awwphooey 1996-2004 Mustang GT 7 01-03-2013 02:43 PM
99-04 Mustang GT ENGINE BLOWN!!! HELP!!! FORDGT14 1996-2004 Mustang GT 17 09-16-2011 02:11 PM
16 Valve GT To 32 Valve Cobra Engine Swap 504 Stang Rida 1996-2004 Mustang GT 5 08-23-2011 05:29 AM
Engine died at low speed. Could not start engine in hot weather Ucla1998 Pre-2005 V6 Mustang 5 08-09-2011 02:15 AM
3.8l to 4.6l engine swap important steps zrider07 General Mustang Discussion 2 08-04-2011 09:07 PM
10:53 PM
