Can the factory turbo be turned up on boost? - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs || Tech and Talk > 2.3 Mustang
Old 09-27-2014, 11:18 PM   #1
2011 Kona Blue's Avatar
I must say this 4 banger turbo is quite impressive and seems to be bigger news than the 5.0. Does anybody know yet if the factory turbo in the 2015 is maxed out on boost or can you increase the boost on the factory turbo? I'm just wondering besides doing a performance tune, gear swap and some bolt on mods, are we looking at the factory turbo being maxed out for setting its boost? Is someone going to have to buy an aftermarket turbo charger if they want more boost? I've have been told the focus St comes really maxed out on boost so I wonder if this 2.3 is gonna be the same? Does someone know how much boost psi is the factory setting going to be?
Old 09-27-2014, 11:39 PM   #2
I would imagine that the factory turbo will be able able to handle in the 350-400 HP range with supporting mods minimum. But regardless the whole platform is setup for forced induction so at worst case you buy a bigger turbo and will probable be in the 500 HP range. It will probable be a while until we know your answers for sure as I dont believe any customers have these cars yet or there is much aftermarket available for them.
StarzTA17 is offline   Reply With Quote
Old 09-28-2014, 09:21 PM   #3
mustangcoupe's Avatar
Usually when they come with a stock turbo, it's boost isn't maxed, they usually keep it lower to stay safe. So you should have room to up the boost.
mustangcoupe is offline   Reply With Quote
Boost line for boost gauge TooSlow4U 2011-2014 Mustang GT 0 07-20-2012 09:34 PM
Can I get a twin turbo kit to work on a newer model a mustang than what the turbo kit was made for? warrane General Mustang Discussion 4 04-08-2010 11:09 AM
94-98 Factory headers VS 99-04 Factory headers Herbstang Pre-2005 V6 Mustang 2 08-08-2007 04:53 PM
boost controller for turbo set up I_luv_HP&trq Pre-2005 V6 Mustang 23 10-12-2005 10:52 AM
Supercharger -- turbo -- boost drmac Pre-2005 V6 Mustang 2 02-10-2004 05:24 PM
01:22 AM
