2.3L turbo automatic. - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs || Tech and Talk > 2.3 Mustang
Old 03-26-2015, 06:42 PM   #1
Has anyone done a turbo conversion with the stock t3 tranny?
I have an 86 that I am doing a turbo 4 cylinder for, I have had a few people give me grief about not changing it to a 5 speed manual.
What is everyone else's thoughts? Am I setting myself up for failure?
Currently- 1986 2.3L lx notchback, conversion to SVO 2.3L turbo automatic notchback.
xCrystalxMariex is offline   Reply With Quote
Old 03-28-2015, 01:27 PM   #2
Haha. C3. Autocorrect strikes again.
I do have a Garrett t3 turbo for my car though.
Old 04-01-2015, 10:03 PM   #3
i personally would not build around that trans your best bet would be a t5...the teans you speak of does not hold up that well to power
99whitev6 is offline   Reply With Quote
Old 04-02-2015, 12:13 AM   #4
I decided to stay with the c3 for a few reasons. First, switching over is a pain in the @$$. With installing all kinds of stuff, blah blah blah. Not to mention it would set me back another few g's I don't have. My second reason. Burn outs. Nuff said. My third reason is I don't like the lag that human error can create on the strip. I prefer my shifting timed perfect and precise. every time.
The turbo is the last thing being done to the build. It will be back running the stock 4 cyl. Auto 3spd. Until I can have certain things done to the other tranny, bottom, and new head. So that it can withstand the power.
Old 04-02-2015, 02:19 PM   #5
could always look into doing an aod or a 4r70w i saw somewhere where somebody did it.. those hold up well... i guess as long you beefed up the c3 it should hold up to what you throw to it...fingers crossed
Old 04-02-2015, 04:38 PM   #6
From what I've learned I'm thinking about having the flywheel and such ceramiced and installing a high stall torque converter so I can build boost.
Old 05-20-2015, 10:48 PM   #7
olerodder's Avatar
Region: Oregon
Just a word of caution with the C3, it won't hold up to the torque the 2.3l turbo will dish out for long, and trying to beef it up is going to be hard because of a lack of performance parts.
Personally I'd go with an early C4, it's small, lightweight and will stand up to drag racing day in and day out..............plus they are cheap to build.
Back in the early 90's I had an 88 Turbo Coupe and the motor had massaged by Esslinger Engineering with a lot of head work. On the engine dyno it was close to 340hp at the crank..........and it was a really fun car on the road.........to heavy for drag racing.
As for drag racing you are correct, an automatic is the way to go if you want consistency. I used a Mike's Transmission Ultra-Glide behind my SBF.......it was consistently 9.801 to 9.825...without electronics as I'm old school.
Old 05-20-2015, 11:18 PM   #8
Panther140's Avatar
Straight cut gears in a T-5. You will be faster on the strip than the auto you have unless your girl is driving
Panther140 is offline   Reply With Quote
non automatic headlights/automatic turn off silverskoundrel General Mustang Discussion 11 09-07-2013 09:13 AM
turbo 3.8 v6 or swap to (turbo??) 4v dohc 4.6 v8??? morthis32 Pre-2005 V6 Mustang 95 09-07-2012 03:27 PM
looking for turbo for 2001 v6 mustang automatic shaloubin Pre-2005 V6 Mustang 10 11-24-2011 04:58 PM
Can I get a twin turbo kit to work on a newer model a mustang than what the turbo kit was made for? warrane General Mustang Discussion 4 04-08-2010 11:09 AM
Automatic Shift Knobs --- 01 Stang Stang01 The Bar 5 07-28-2003 09:23 AM
11:55 AM
