2.3l turbo - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs || Tech and Talk > 2.3 Mustang
Old 04-09-2015, 02:25 PM   #1
2.3l turbo
So I found a 2.3l turbo motor out of a 83 and I want to swap it to my 93 notch mustang it's already a 2.3l just not turbo what will I run into and what do I need to change?
1993 Foxbody Mustang Coupe
Vic__3 is offline   Reply With Quote
Old 05-22-2015, 10:29 AM   #2
olerodder's Avatar
Region: Oregon
First off, what car was the donor?
A lot of the early 2.3l turbo's are pretty much boat anchors as they had a blow through turbo setup. Starting in 83 the Mustang and Carpi got EFI and non-intercooled. The heads on the turbo 2.3l were pretty much garbage and with enough work can add some serious HP to an intercooled motor. The non-intercooled motors used a T3 turbo and the air-to-air intercooled used a more responsive Warner Ishi (IHI) turbo.......although a lot of people say this turbo is junk it managed to push my 88 Turbo Coupe to mid/high 13's in the quarter mile some 15+ years ago.......although I did have a head that was massaged by Esslinger.
So to answer your question you will need to replace the "brains" from donor car along with everything else associated with the turbo.
The one downside here is that the 2.3l weighs as much as the 5.0l V8.
turbo 3.8 v6 or swap to (turbo??) 4v dohc 4.6 v8??? morthis32 Pre-2005 V6 Mustang 95 09-07-2012 04:27 PM
Can I get a twin turbo kit to work on a newer model a mustang than what the turbo kit was made for? warrane General Mustang Discussion 4 04-08-2010 12:09 PM
Super and Turbo chargers together. Horse Pre-2005 V6 Mustang 13 12-21-2003 11:37 PM
T-bird Turbo Coupe?? fast64 The Bar 3 11-05-2003 09:37 AM
I got some Dynomax Thrush Turbo Mufflers fast64 Pre-2005 V6 Mustang 4 07-25-2003 06:18 PM
01:17 AM
