Compression 2.3t - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs || Tech and Talk > 2.3 Mustang
Old 08-16-2016, 03:25 PM   #1
Compression 2.3t
Hey everyone. I have a 2.3 turbo in my 88 xr4ti. She runs great when I pull but at idle it misses kinda bad. I've been through everything in the ignition system. I checked my compression on 2 cylinders, while it was cold. One was 92 the other was 65. (Supposed to be 140ish? ) The car has a lot of power and runs really good other than at idle. Is it time for a rebuild? Or maybe I'm off on timing? Any suggestions are great if I gotta rebuild I have a roller fox it's going into.
Crak88lx is offline   Reply With Quote
Old 08-18-2016, 11:49 PM   #2
Yes. Those two cylinders are low.
It's possible that there is a problem with the valves. Or perhaps a blown head gasket could be the culprit... Especially if the two cylinders with low compression are next to each other.
Old 08-19-2016, 05:50 AM   #3
Ok that helps a lot. I was talking to my ASE master at work he suggested a retime before I junk it just to be sure.
Sent from my XT1565 using Mustang Evolution mobile app
Old 08-22-2016, 08:41 AM   #4
Update: so timing cover is off the belt is newer but the gears and tensioner...not so much, so it very well could have slipped a tooth or two. Not holding my breath,but would be nice to drive this again before snow hits.
Old 09-02-2016, 09:17 PM   #5
Update: I have retimed and had slightly better compression. About 20psi more at running temp. Sad to say the motor is blown. It runs and drives ok but idle not so much. So there will be a rebuild when I'm done with my small block.
e6te head compression ratio questions svtlx 1979-1995 Mustang GT 10 03-20-2007 08:58 AM
what's an ideal compression ratio I_luv_HP&trq Pre-2005 V6 Mustang 15 10-16-2005 07:19 PM
Low Compression from Cylinder #2 robert0803 Pre-2005 V6 Mustang 14 04-08-2005 09:44 PM
compression Js281GT 1996-2004 Mustang GT 17 01-10-2005 06:01 PM
Compression questions. Horse Pre-2005 V6 Mustang 5 06-15-2004 06:01 PM
06:51 PM
