PPRV delete, wish me luck....! - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > Other Special Edition
Old 07-27-2011, 05:24 AM   #1
drusmith's Avatar
Send a message via Yahoo to drusmith
7:23 started the PPRV delete. I have my final dyno tune tonight at 7. Hope it all goes good.
drusmith is offline   Reply With Quote
Old 07-27-2011, 07:12 AM   #2
Re: PPRV delete, wish me luck....!
good luck
Old 07-27-2011, 07:20 AM   #3
drusmith's Avatar
After taking care of mutiple work emails and other BS. Got her out. Not to hard at all. About 1 hour work time.
Old 07-27-2011, 07:21 AM   #4
do a write up on it take good pics ill get an article up
Old 07-27-2011, 07:30 AM   #5
drusmith's Avatar
PPRV, little white thing. Bastard!
Old 07-27-2011, 10:28 AM   #6
drusmith's Avatar
Well car runs like crap. No fuel pressure on fuel gauge. 10.2 on Air/fuel gauge. THis sucks. GD F-ing S
Old 07-27-2011, 10:46 AM   #7
Titus Wadicus
svtlx's Avatar
and a pprv is....? seriously, i dont know wut it is.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 07-27-2011, 11:04 AM   #8
drusmith's Avatar
Parallel Pressure relief valve
Old 07-27-2011, 11:25 AM   #9
Titus Wadicus
svtlx's Avatar
i knew that, just making sure you knew. so u got a bad one?
Old 07-27-2011, 11:47 AM   #10
USAF_stang's Avatar
I don't know what the function of this is...someone school me please lol.
USAF_stang is offline   Reply With Quote
Old 07-27-2011, 12:01 PM   #11
drusmith's Avatar
Ok got it!!! It was a loose clip on one of the hoses for one of the fuel pumps. Runs great now! 2nd time around that tank sure came down faster. LOL Air/Fuel ratio is good idle at 14.5-15 and about 11.2 into the throttle.
PPRV is for nothing but giving more life to the fuel pumps. It is only good for stock Cobras(03-04). Once you do more and more mods to your Cobra the make it faster there is a hesitation that occurs due to this valve not being able to keep up with the fuel demand.
Anywho, I am ready for Dyno tonight! I hope this stupid rain stops!!!!
Old 07-27-2011, 12:02 PM   #12
USAF_stang's Avatar
Gotcha. So its basically just a valve that opens and shuts to feed fuel? Good luck on the dyno man.
Old 07-27-2011, 01:18 PM   #13
drusmith's Avatar
Yeah its kinda like that. the PPRV delete kit comes with a "Y" and fuel lines. $80! Not bad for consistent fuel delivery.
Thanks I will POST Dyno results tonight!!
Old 07-27-2011, 01:30 PM   #14
drusmith's Avatar
Also installed new aluminum tanks.
Old 07-27-2011, 05:23 PM   #15
Just to add some clarification, the pprv serves to keep pressure in the fuel lines so that when you start up the lines are pre-pressurized.
The down side is, even on stock cobras, the pprv can actually cause a slight hesitation in fuel delivery between shifts at wide open throttle causing an uber lean condition and possibly making something go pop.
Old 07-27-2011, 08:08 PM   #16
Las0mbra's Avatar
Dyno results?!
Old 07-28-2011, 06:45 AM   #17
drusmith's Avatar
Dyno Results! 590wrhp with 550 torque. Great tune! Air/fuel settings are great! timing is set at a good medium nothing aggressive! I will download video to you tube and post that as well.
Old 07-28-2011, 06:54 AM   #18
drusmith's Avatar
Dyno sheet
Old 07-28-2011, 08:50 AM   #19
whats up with the A/F cant read what rpm what is, looks like it jumps around a bit~
Old 07-28-2011, 09:57 AM   #20
That A/F is a bit out of control. Can't tell what the numbers are related to the lines...but it looks a bit lean at the start and is definitely starting to lean out on the top end where it shouldn't.
Do you have actual numbers as to what your A/F is climbing up to on the top end?
Old 07-28-2011, 12:15 PM   #21
drusmith's Avatar
A/f jumps down to 10.5 then back up to 11.7-12. A/f was good throughout really. The graph doesn't show it very good.
Here's the video of the Dyno:
Old 07-28-2011, 12:26 PM   #22
A/f jumps down to 10.5 then back up to 11.7-12. A/f was good throught really. HTe graph doesn't show it very good.
That's way too rich at 10.5 and it's getting risky lean up top with 18psi. What kind of max timing are you running? 11.7 isn't always a bad thing, but up top it could get finicky about what gas is in the tank. I ran mine like that for years and would get detonation with anything other than chevron.
Old 07-28-2011, 12:28 PM   #23
Btw, who did the tuning?
Old 07-28-2011, 12:39 PM   #24
drusmith's Avatar
Yeah that little dip they couldn't figure out. They said that it looks longer then it really was. Basically it was when he pushed to full throttle and it came back to where it should be for A/F. The timing I don't remember the number but he said it was not aggressive and was perfect! The guy who tuned my car works for High Performance Engines - Race Engines - ProCharger - SMRE Performance he builds and tunes high performance motors. Visit the site, they sell a motor for $80k. So I trust in the tune he has provided, it wasn't his first Mustang nor his first Terminator.
Anyway my car has never perform better just on the ride home!!! It feels so much better and 100% better throttle response!!! First visit to the track will be next Friday!
Old 07-28-2011, 12:57 PM   #25
keep a listen for detonation and check the plugs after a bit of driving and keep an eye on them and you should be good to go.
Old 07-28-2011, 01:19 PM   #26
Definitely listen for detonation up top. You won't hear it down low being as rich as it is.
Old 07-28-2011, 01:24 PM   #27
drusmith's Avatar
Thanks guys! And yes both Tim (ZZP) and Ryan (Tuner) said after 2 weeks re-gap or check plugs! I will keep an ear out for detonation: remind me what that sounds like! Big pop or bang right.
Old 07-28-2011, 01:35 PM   #28
No, marbles in a can...or yatzee dice in a cup.
Old 07-28-2011, 01:41 PM   #29
drusmith's Avatar
Gotcha!! So your saying you heard that in my video or just to keep an ear out for it! I know Detonation is when your fuel is ignited before the piston has reached the end of its up stroke. Just not sure if your saying I have this problem.
Old 07-28-2011, 02:11 PM   #30
I'm saying listen for it. I didn't watch the video, but you won't hear it from outside the car anyhow. You'll hear what sounds like marbles in a tin can coming from the floor boards or the dash area.
Old 07-28-2011, 02:24 PM   #31
drusmith's Avatar
Okay now i gotcha! thanks for this info. I have always heard about Detonation but never experienced it myself. I will keep an ear out for this sound. Check it out!
‪Drew's Kenne Bell 2.2L terminator Dyno‬‏ - YouTube
Old 08-05-2011, 10:00 PM   #32
Meansaleen's Avatar
Pretty funny how there's a couple of heineken bottles next to your car.
Meansaleen is offline   Reply With Quote
5.0 emblem delete LaFlamaBlanca 2011-2014 Mustang GT 23 08-05-2011 03:29 PM
Bad luck... Blackedout Pre-2005 V6 Mustang 20 07-29-2011 07:50 AM
Just my luck. nickysixx 1996-2004 Mustang GT 53 07-23-2011 09:38 AM
04:53 AM
