Startup occasionally sluggish, normal? - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > Other Special Edition
Old 06-04-2012, 08:32 AM   #1
Lorraine's driver
ab_mach1's Avatar
Okay, 95% of the time I start my Mach, VROOM! No probs nice and clean and consistent. The other ~5%, it will go VR..oom, like it's bogging at startup. And this usually happens after I've driven it somewhere and shutoff the car for a few mins to an hour. Then, the next time, VROOM! no probs. I have changed the plugs (Motorcraft) and the fuel filter recently, but that hasn't changed this occasional prob at all. Should I worry about this?
Instagram: @ab_mach1
Old 06-05-2012, 11:14 PM   #2
slow281
sixpac's Avatar
Region: Nebraska
It might just be the temp? I would check all your wires for your air intake sounds like your MAF may be miss reading at times get some MAF cleaner and electrical wire cleaner and see if that helps..
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 06-05-2012, 11:17 PM   #3
Lorraine's driver
ab_mach1's Avatar
Cleaning the MAF w/MAF cleaner, do you spray it directly or apply with a Q tip or something like that?
Old 06-11-2012, 07:40 PM   #4
TtownMach1's Avatar
Spray directly but a gentle stream. Try not to blast the sensor up close. Cleaned my maf with this back when I changed the plugs. Seemed to do it's job I was having some slight start up/idle issues. Make sure to let the sensor dry before reinstalling. Hope this helps man
5-Speed-IUP, Predator tuned, k&n cai,Mrt shifter,Hooker Lts-o/f x-pipe, KC clutch,Alum flywheel,FR 4:10's. Upr rear control arms. Forged Teksid Eaton swap in progress!
WickedStangs Mustang Club
Tulsa,OK Chapter President
TtownMach1 is offline   Reply With Quote
Old 06-11-2012, 08:15 PM   #5
Lorraine's driver
ab_mach1's Avatar
Cool, thanks man! I'll give that a try. Do you need to do anything with throttle body at certain mileage intervals?
Old 06-11-2012, 08:32 PM   #6
TtownMach1's Avatar
No problem! As to the throttle body I'm not 100% sure. BG also makes this for t-body/intake (top right of picture). I haven't tried it yet, but I hear nothing except good things about it from the techs at work.
01:06 PM
