Question - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > Other Special Edition
Old 06-27-2012, 06:39 PM   #1
nathan2393's Avatar
Question
I have a 03 mach 1 and I straight pipped it and now it has a bogging problem because the back pressure would 12 inch cherry bombs fix it?
nathan2393 is offline   Reply With Quote
Old 06-30-2012, 07:01 PM   #2
Mezmer's Avatar
Re: Question
Or, you could get a good sounding muffler like a Flowmaster 40 Series or Bassani.
2004 Mustang Mach 1 - SY
Exhaust - Wanna be Flomasters...
JLT Ram Air Intake
SR Performance Short Throw Shifter
Mezmer is offline   Reply With Quote
Old 07-04-2012, 03:02 PM   #3
Lorraine's driver
ab_mach1's Avatar
Re: Question
Do you have a check engine light showing? Also, do you still have the O2 sensors in your system? if not, that could be causing it to run bad.
Instagram: @ab_mach1
Old 07-05-2012, 07:09 AM   #4
nathan2393's Avatar
I still have my o2 sensors and I dont have a check engine light on
Old 07-05-2012, 07:39 AM   #5
Lorraine's driver
ab_mach1's Avatar
I cleaned my IAC and that cured the little bit of bogging I had, but that doesn't really explain your change with going to straight pipes. Unless its just a coincidence? It's pretty easy to clean. It's attached to the throttle body on the firewall side.
Old 07-05-2012, 11:47 AM   #6
nathan2393's Avatar
Do you clean it with anything specific?
Old 07-05-2012, 12:20 PM   #7
Lorraine's driver
ab_mach1's Avatar
Yup, I cleaned mine with throttle body cleaner. When I cleaned it, I kept the end with the wire connector up high to make sure I didn't get it wet. I also used a Q-tip, but make sure you don't leave any Q-tip material inside.
Old 07-05-2012, 03:13 PM   #8
nathan2393's Avatar
Alright I will try that
« Tuners | insurance »
08:52 AM
