Radiator puking! - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > Other Special Edition
Old 12-01-2013, 05:51 PM   #1
Mach1Gunshow's Avatar
Radiator puking!
First thing is I have replaced waterpump, thermostat( 4 different ones), cap,and had the system burped by two different radiator shops who have burped mach1's before!! Also had the system checked with a temperature gun to see if it circulating witch it is!! Also had a head gasket test done there is no oil in water and no water in oil and still drives fine and said head gasket test showed it was fine! Also a leak test!! All show fine but after bleeding about a day or so later it pukes again! I think it's the head gasket but not wanting to spend the money if I'm over looking something!! If someone has seen this I could use some advise! Like I said I think it is the head gasket but not sure!! If this problem has been on the forum before, sorry I didn't see it!
Mach1Gunshow is offline   Reply With Quote
Old 12-01-2013, 06:13 PM   #2
87LX306's Avatar
Did the shop test for exhaust gases in the antifreeze? Good way to burp most vehicles is to let her run and pop the "outlet" heater hose. If there is air she will spit a bit, once you get steady flow hook the hose back on.
87LX306 is offline   Reply With Quote
Old 12-01-2013, 06:16 PM   #3
Yeah they did that! I've owned another mach1 and never had this problem!
---------- Post added at 08:16 PM ---------- Previous post was at 08:15 PM ----------
They did the exhaust fume test!! Is there a test that test the antifreeze?
03:50 AM
