2003 Mach 1 - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > Other Special Edition
Old 04-10-2014, 07:00 PM   #1
Zinc's Avatar
2003 Mach 1
So I'm going to trade in my v6 for a Mach 1
What mods should I do ?
It already has upgraded intake
I was thinking the bbk shorty headers with a pypes off road x-pipe with pypes bomb exhaust system with 3.5 inch tips and straight pipe it from there.
So like what wheels or performance or body mods should I do?
Zinc is offline   Reply With Quote
Old 04-10-2014, 07:02 PM   #2
Doe_Rae_mi's Avatar
Just lower it. And chose the wheel you prefer. That's all u need to do and it will be sexy
Old 04-10-2014, 07:05 PM   #3
Zinc's Avatar
I ment to say I'm already getting lowering springs
Old 04-10-2014, 07:16 PM   #4
Doe_Rae_mi's Avatar
Just do that and wheels for the body!
Old 04-10-2014, 07:17 PM   #5
Zinc's Avatar
So I was thinking about the 2001 cobra front
Old 04-10-2014, 07:27 PM   #6
Doe_Rae_mi's Avatar
Yes and that to didn't think about that lol
Old 04-13-2014, 06:29 AM   #7
Chapka's Avatar
I jst bought an azure blue 04 mach 1. A short throw and 4.10 gears really wake up Machs
America is all about speed - hot, nasty, badass speed
Chapka is offline   Reply With Quote
Old 04-14-2014, 08:14 PM   #8
Black99Snake's Avatar
Don't waste your money on the shorty headers just buy the long tubes. Gears and wheels. What color is the mach? Great upgrade from a v6 huh? I went from a v6 Silverado to my cobra
1999 Cobra black with medium parchment interiorJLT CAI, RWR motorsports tune, Pacesetter Longtubes, o/r xpipe w/cutouts, Flowmaster Super 44s, built t56, Kevlar clutch, Nitto NT05R, Ford Racing 4.10 gears, MMR 900 rotating assembly, vortech v3 si, twin aeromotive 340s, aeroquip lines, 80lbs injectors
Black99Snake is offline   Reply With Quote
Old 04-15-2014, 10:14 PM   #9
Zinc's Avatar
Red . With 100,000 miles
What alert would I have since it's at 100000 miles, like what parts should I replace?
Old 04-15-2014, 10:35 PM   #10
Zinc's Avatar
Also I want straight pipe what is the best?
X-pipe?
Headers?
Axleback system?
I want it louder than my friend he has a azure blue and running pypes o/r xpipe, and flowmaster cast back system with no manifolds
But I don't want it to sound ugly but I want it to sound like people hear me down the street but a clean sound!
Old 04-15-2014, 10:38 PM   #11
Zinc's Avatar
X-pipe?
Headers?
Axleback system?
Old 04-15-2014, 11:05 PM   #12
I'm running pacesetter long tubes, summit racing off road x pipe with cutouts, flowmaster super 44s all 3in. Sounds really loud, throaty and raspy but not obnoxious loud like ***. Pacesetters were around $300 from summit racing. And the mid pipe is what your preference x is raspy and h is not. I forget which one nets you power and what power range. I did muffler and cat deletes the day I got mine and it sounded loud but ran like crap in my opinion.
Old 04-16-2014, 05:36 AM   #13
Kooks headers, Bassani X, SLP Loudmouth Catback...
txffmike is offline   Reply With Quote
Old 04-16-2014, 05:38 AM   #14
Keep those Mach wheels on the car! Machs are clean already!
Old 04-16-2014, 07:31 AM   #15
Chapka's Avatar
+1
Old 04-18-2014, 11:27 PM   #16
Zinc's Avatar
I don't want to spend over $1100 on my exhaust so what is the best straight pipe system?
Old 04-19-2014, 07:33 AM   #17
Don't straight pipe, the car needs back pressure.
Old 04-19-2014, 10:32 AM   #18
Mile high JDF's Avatar
If it needs back pressure then why go with a wider diameter pipe??? Why not put a 1" exhaust on if you want more back pressure? If you mean exhaust velocity then yes that's always a good idea. Straight through mufflers don't exactly do much more than straight pipes when you look at the muffler design.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-19-2014, 11:14 AM   #19
You need restriction in the exhaust. Or burn your valves.... Your choice.
Old 04-19-2014, 11:19 AM   #20
ToHellAndBack's Avatar
That's not even a little bit true. A car needs exhaust VELOCITY not back pressure. Back pressure is a myth. A less restrictive exhaust nets more horsepower and believe it or not MPG depending on how you drive. Removing cats and even mufflers with straight pipes will not hurt your car except it may not sound very pleasant. When you drastically increase the diameter of your pipes is when you run into trouble.
"I'm not tailgating... I'm drafting"
ToHellAndBack is offline   Reply With Quote
Old 04-19-2014, 11:45 AM   #21
Then why don't you shove a Potatoe into your tail pipe? If you needed restriction then why does everybody upgrade to wider pipes? I don't know about you, but I have yet to see a forum post about somebody burning a valve at all, let alone a burnt valve cause by "lack of back pressure". Yes an exhaust will always have back pressure, that's a by product of putting any sort of exhaust on an engine, but what's the point of putting something to exhaust the combustion gasses out of the area if you just plan on forcing it to stay in the combustion chamber?
Old 04-19-2014, 11:51 PM   #22
Zinc's Avatar
So what is a good setup?
Old 04-20-2014, 01:12 AM   #23
That all depends on what sound you like. I've got an O/R X with the Magnaflow SS catback and I loveit, but it's quieter than most guys like.
Old 04-20-2014, 08:09 AM   #24
Psikosocial's Avatar
I'm doing a bbk o/r x pipe with flowmaster mufflers. It's definitely loud. And sounds great but when you get to the higher rpms it gets really raspy
Psikosocial is offline   Reply With Quote
Old 04-20-2014, 03:24 PM   #25
Eturner's Avatar
That is why you don't mix Chambered Mufflers with an X-Pipe!..
Old 04-20-2014, 03:34 PM   #26
Doe_Rae_mi's Avatar
Off-road x and loudmouths or off-road x and borla stingers
Old 04-20-2014, 04:55 PM   #27
FullyAutomatic's Avatar
Region: Mexico
post pics of the mach 1..
FullyAutomatic is offline   Reply With Quote
Old 04-26-2014, 08:10 PM   #28
-Suspension
-Mid pipe
-Catback
-Gears
-Shifter
-Wheels/tires
-Tune
That is a 12 second car with a good driver.
2003 mach 1
Mach 1 SOLD :: 2003 Ford Mustang Mach 1 MustangGT02 Member Garages 2 07-05-2013 06:12 AM
2003 Mustang GT :: 2003 Ford Mustang GT Brent Member Garages 0 06-15-2011 12:01 PM
2003 Ported and Spray'd Cobra vs 2003 Turbo Cobra Whipple Mustang GT vs FRC Corvette BoostedB18c Pictures and Videos 0 06-07-2008 10:07 PM
2004 Mach 460 head unit in a 2003 SpectorV Mustang Audio & Video 3 04-03-2006 06:36 PM
04:53 AM
