advise mach 1 motor rebuild - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > Other Special Edition
Old 02-27-2015, 05:47 PM   #1
So 03 mach 1 is coming close to be rebuild my piston rings are going bad.. has anyone rebuild there engine and how much did it cost.. I'm not trying to build a 800 motor .the most I want is about 450 but can a stock motor do it?
dsgmach03 is offline   Reply With Quote
Old 03-02-2015, 07:09 PM   #2
I think you'd be lucky to see 350-380 rwhp after cams, ported intake, head work (though the c heads are just fine imo), and all the usual bolt ons.
It'd be much easier and cheaper to run a low boost centri application and some 4.10's for a solid 400+ street car.
Do some digging on the registry or SVT performance, majority of guys looking for 400rwhp are opting for FI of some type. A couple guys have gone the n/a route but I believe they spent more to achieve a naturally aspirated 400hp than the guys going FI and seeing 500hp with some coin left for suspension etc.
Old 03-06-2015, 01:10 PM   #3
What about an Eaton or Kenny bell
Old 03-07-2015, 05:41 PM   #4
A roots or twin screw will work, but keep in mind you won't want to run a ton of boost on stock internals or you'll be on borrowed time. The rods are the weak element in our N/A 4v's.
There are quite a few guys running Eaton M112's from the Termi's on stock internals but most are no higher than 10lbs, which is preferable since the more boost, the more heat that thing generates, it isn't call the "heaton" for nothing lol.
Also if you run a positive displacement blower and want to keep the shaker, you'll have to either fab up a mounting bracket over the blower or get creative and attach it to the hood. The second option won't keep the shaker "functional" but at least it will still be there like it should on a Mach.
Old 03-08-2015, 02:04 PM   #5
Cool thanks man for the info appreciate
Old 03-08-2015, 02:05 PM   #6
Like I said I'm trying to push around 450 not trying to go big
motor rebuild? sixpac General Mustang Discussion 0 03-29-2013 12:35 PM
Motor rebuild. Thrasher13 1979-1995 Mustang GT 1 07-08-2012 06:56 PM
Whats it cost to rebuild a motor? sixpac General Car Discussion 3 07-02-2012 11:32 PM
rebuild of a recent rebuild Black99Snake SVT Mustang 12 08-20-2011 05:24 PM
donor rebuild vs current engine rebuild cash05_mustang Pre-2005 V6 Mustang 2 07-01-2006 01:09 PM
08:50 PM
