Mach 1 misfire?? - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > Other Special Edition
Old 03-04-2015, 01:59 AM   #1
Ksantos's Avatar
Mach 1 misfire??
So I just recently started getting a really bad stutter in my car when trying to accelerate
Ksantos is offline   Reply With Quote
Old 03-04-2015, 02:03 AM   #2
Ksantos's Avatar
And the car has an even worse stutter when it idles. I took it to the mechanic and they said it was a misfire in cylinder 5. So we changed the coil pack with ford OEM parts and we also changed the spark plugs and I'm still having the same problems. Any suggestions tips I need some help?!?!
Old 03-04-2015, 09:33 AM   #3
Try swapping the #5 fuel injector with one from another cylinder and see if the misfire follows the the #5 injector to the cylinder that you move it to.
Also, a lack of compression will cause a misfire. So, if you can't find a failed part (injector, coil, spark plug, or a bad electrical connection) then a compression test is in order to verify the condition of the engine.
straybullitt is online now   Reply With Quote
Mach 1 SOLD :: 2003 Ford Mustang Mach 1 MustangGT02 Member Garages 2 07-05-2013 06:12 AM
Mach 460 with Mach 1000 Subs XSlashDashX Mustang Audio & Video 2 05-31-2013 12:07 PM
Mach 1 Tangerine! :: 2004 Ford Mustang Mach 1 Nel86 Member Garages 3 06-16-2011 02:21 PM
02:39 PM
