Raising Mach 1 Shaker - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > Other Special Edition
Old 06-22-2015, 04:00 PM   #1
infamous281's Avatar
Decided to post this DIY for the Mach 1 guys ..
A very cheap and easy way to raise the shaker to make it look better.
Stock look
1. Remove shaker .. there are (2) 10mm bolts on the sides of the shaker. Remove the 2 lines on the driver side of the shaker. Remove the air duct from the airbox.
The front of the shaker bracket has (2) 10mm bolts unbolt them , and apply washers underneath of the bracket , then bolt the (2) 10mm bolts back down.
Reinstall everything and your shaker will be raised !
I also applied some silver paint marker to the shaker to make it look better as well.
Enjoy
Sent from my SM-N910T using Mustang Evolution mobile app
ID:	185551   Click image for larger version
ID:	185553   Click image for larger version
Old 06-22-2015, 04:03 PM   #2
Here's how the washers will look under the bracket .. forgot to upload a picture.
Old 07-15-2015, 08:12 PM   #3
Nice write up. That shaker is up in the clouds now! lol.
I feel this method is much safer than the other method of physically raising the ball joint sockets on all four corners.
The rear sockets can be lifted too much (>1/4"), put too much pressure on the hood and possibly cause it to crack if you were to hit a large bump.
I may throw a few washers in on mine and see how it looks.
any tips on raising my Roush mustang a little bit off the ground? memo232 Roush Mustang 34 11-14-2011 10:18 AM
Raising speed limiter Blackedout Pre-2005 V6 Mustang 28 04-19-2011 08:24 PM
Raising the rev limiter with a tune Blackedout Pre-2005 V6 Mustang 19 03-18-2011 08:17 PM
raising the spedometer charkelly9 Pre-2005 V6 Mustang 21 09-06-2004 05:25 PM
Lowering/Raising question Exit_In_Red Pre-2005 V6 Mustang 9 08-11-2004 10:15 PM
04:34 PM
