Mach 1 shaker issues - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > Other Special Edition
Old 02-04-2016, 06:05 PM   #1
superdrift's Avatar
As you can see in the picture one side is slanted, the shaker also rattles allot and will slightly move bounce at the front. Is there a solution to fix this?
ID:	196641   Click image for larger version
superdrift is offline   Reply With Quote
Old 02-04-2016, 09:49 PM   #2
Could be a few things...
One of your spherical mounts might be broken on the passenger side causing the sag. Remove the two 10mm bolts located on each side of the shaker. Gently lift up on the shaker to remove it from the spherical mounts. If one is missing you'll want to replace it.
If all 4 of them are fine, it could be that the shaker itself is just loose or the isolators were removed by a PO. Mine was rattling shortly after I got it and found out the isolators were shot and allowing the shaker to rattle, bounce excessively.
I replaced the worn out isolators with a new nylon spacer and a couple rubber grommets to quiet it down. Did it a in June of '14 and it has been fine so far.
Years ago there was a TSB issued for shaker rattle. The factory isolators that the front of the shaker rests on were junk and needed to be replaced. The link below has some good info.
Mach 1 shaker scoop squeaks & rattles....HELP!!!! | Mustang Forums at StangNet
Old 02-04-2016, 09:53 PM   #3
superdrift's Avatar
Thanks for the help, ima try it out tomorrow
Old 03-01-2016, 08:17 AM   #4
Lorraine's driver
ab_mach1's Avatar
Mine was clunk real bad when I hit bumps and the connection over at the air box would pop apart on each drive. I bought new shaker isolators and it fixed all that for me. There are nubs that are screwed into the shaker housing and these nubs sit down right in the isolator cups. The part number is 2L7Z-9P686-AA. I bought mine at the link below.
http://parts.autonationfordwhitebear...rd/2l7z9p686aa
IG: @rcodemach1
Instagram: @ab_mach1
Old 03-01-2016, 10:17 AM   #5
superdrift's Avatar
IG: @rcodemach1
I found out its not my shaker, i raised it and it doesnt make the clanking noise, i honestly dont know what it could be
Old 03-02-2016, 08:07 AM   #6
Lorraine's driver
ab_mach1's Avatar
Hmmm, if your shaker mounting points look good, maybe your shaker bracket is missing bolts on that side..? You might want to get the shaker off again and have a look. I know my bracket has some rust around the shaker mount holes. I guess if it was bad enough, it could cause it to lean if the rust gave out. I need to repaint mine. I suck at painting lol.
IG: @rcodemach1
Old 03-02-2016, 08:26 AM   #7
superdrift's Avatar
IG: @rcodemach1
I dont think its my shaker rattling anymore, im hoping it has something to do with my exhaust cause i think i have a leak
Old 03-02-2016, 08:29 AM   #8
Lorraine's driver
ab_mach1's Avatar
Oh okay, glad it's not the shaker. So it's level now too? Hope you find its something simple to fix on your exhaust. Maybe a hanger grommet that's shot or something.
IG: @rcodemach1
Old 03-02-2016, 02:10 PM   #9
superdrift's Avatar
IG: @rcodemach1
Yeah when i raised it it evened it out. Im probably gonna have to get a new midpipe or headers but at least thats a part that i can upgrade
2010 GT - issues, issues, issues. Anyone experience this? Binks 2005-2010 Mustang GT 2 05-09-2015 10:22 AM
Shaker 500 to shaker 1000 Magua10 2005-2010 Mustang GT 7 05-12-2014 06:20 AM
Looking for " mach 1" shaker inserts? MachMan1017 General Mustang Discussion 4 10-16-2012 07:25 AM
Mach 1 hood and shaker 2002VertGT 1996-2004 Mustang GT 17 02-23-2012 02:27 PM
mach shaker system Dark02Pony Mustang Audio & Video 2 07-08-2005 09:49 AM
09:30 PM
