Storing my 12 gt500 - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > Shelby Mustang
Old 03-03-2013, 01:06 PM   #1
Jguida's Avatar
Storing my 12 gt500
Do I need to disconnect the battery or trickle charge it?? For about 6 months it won't be used
Jguida is offline   Reply With Quote
Old 03-03-2013, 01:52 PM   #2
Mlarv5's Avatar
Is it going to be inside or outside? I would say a trickle charger will do the trick to keep the battery up to speed I have seen some solar ones that will keep it charged.
If inside I would jack it up and leave the wheels on. If it is out side make sure it is not under a tree or anything where birds can sit and do there thing, also keeps the sap off it. They make all weather covers for them but I am not sure about them.
Now do you have someone you trust to start it every once in awhile. If so that is the best thing to do. I would change the oil when I pulled it out of storage. I have stored many cars over the years when I deployed for 6 or 7 months outside at my parents house without any problem my dad would go out and start the car every once in awhile. He would hook up a battery charger the day before I would come get it.
Hope this helps
1968 Coupe <53000 miles on her 289 came off the line Jan 21st 1968. I bought it in 1983
2013 Shelby GT500 Born 12/06/2012 number 439 of 530 in DIB and 1 of 9 with Red Stripes over the top and on the seats
Mlarv5 is offline   Reply With Quote
Old 03-03-2013, 02:15 PM   #3
1slosix's Avatar
i will also add in to this since it'll be sitting...go ahead and let about 10 lbs of air out of the tires when you park it...that'll help keep the tires from going bad while you're away from the car
carving corners like a boss
Old 03-04-2013, 07:38 AM   #4
Jguida's Avatar
Alright perfect, thank you
Old 03-04-2013, 08:00 AM   #5
rebeltx's Avatar
Don't forget a fuel treatment. Gas will turn to a goopy mess over time that will reak havoc on the fuel system. People seem to like that sta-bil stuff.
"Turn the mic back on" -Winston Churchill
rebeltx is offline   Reply With Quote
Old 03-04-2013, 09:15 AM   #6
pick up a Battery Tender brand trickle charger and keep that on it (set it up so it doesnt sit on the floor (i wouldnt at least)
Old 03-04-2013, 10:03 AM   #7
FORDuhl6's Avatar
+1
FORDuhl6 is offline   Reply With Quote
Old 03-04-2013, 10:08 AM   #8
Skulls98GT's Avatar
+11
The best is the Battery Tender. They have a feature that shuts off the charger when the battery is full and then turns itself back on when the charge starts to drop again. This way you won't "cook" your battery.
Skulls98GT is offline   Reply With Quote
Old 03-05-2013, 04:47 PM   #9
Jguida's Avatar
Battery tender was delivered and hooked up and 10lbs of pressure have been let out of the tires, thanks guy!
Old 03-12-2013, 06:48 AM   #10
Filf's Avatar
I always put staybil in the fuel, a battery tender and I add 10 lbs of air into the tires. I also have a bubble the car sits in all winter long. http://carcapsule.com/
Filf is offline   Reply With Quote
Old 03-12-2013, 07:46 AM   #11
dj_james123's Avatar
Yea i would over inflate the tires a little bit, because then the tires don't get a flat spot on it, and your not thumping down the road, because the day you take it out that extra 10-15 will be gone
dj_james123 is offline   Reply With Quote
Old 03-12-2013, 08:09 AM   #12
Jguida's Avatar
Wait add 10lbs not take out? Won't that over inflate them?
Old 03-12-2013, 08:35 AM   #13
you may want to consider leaving it on stands or those things you sit the tires on to keep them from getting bad flat spots even with lower psi, but may want to have rubber mounts if you store on stands to keep metal on metal from going to the floor
Old 03-12-2013, 09:05 AM   #14
Filf's Avatar
I've always heard over-inflate so that you won't get flat spots. But even still, the tires these days aren't as prone to flat spots so if the car isn't going to be stored for several months to years I wouldn't worry too much about flat spots. You may hear some thumping when you first drive the car but it will disappear rather quickly.
I store my car 6 to 7 months of the year, I overinflate the tires and I have never had a problem with tires, gas, or battery issues using the advice I gave above.
Old 03-12-2013, 09:07 AM   #15
^^ good to know, thanks for the info
Old 03-12-2013, 02:23 PM   #16
Right now my car has a battery charger to it.
The thing is called "charge it" from napa, $50,
I keep it running all the time, and keeps my battery stable, and I go out once in awhile to start it up
03:30 AM
