Wheel hop - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > Shelby Mustang
Old 03-22-2013, 09:16 AM   #1
BossCNC's Avatar
Region: Arkansas
Wheel hop
I cannot believe there hasn't been anything posted in here about the wheel hop on the GT500. I've searched, but don't see any threads...so here goes mine.
What's the best remedy to eliminate it or at least greatly reduce it?? My 2009 Shelby is becoming less & less fun to drive because it's so pronounced. And now I have a "Check Traction Control" message that pops up in conjugation with the hop, even with TC turned off. Happens in any gear that will spin the tires 1st - 3rd. Any suggestions??
BossCNC is offline   Reply With Quote
Old 03-22-2013, 09:38 AM   #2
sprdave's Avatar
Well,The only thing I could say is maybe putting on lower control arm brackets
that increase the effect of the control arms and maybe after market heavy duty
control arms.Do you have it lowered at all?
Maybe if it was lowered it might also help the wheel hop.
sprdave is offline   Reply With Quote
Old 03-22-2013, 09:40 AM   #3
The Blue Dragon
GrabberBlue5.0's Avatar
replace the lower control arms and install relocation brackets
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 03-22-2013, 10:53 AM   #4
1 Alibi 2's Avatar
Installed a double adj. UCA and billet LCA's, seems to have solved the problem..
There are no threads because we just take care of it..
2014 - detuned to 780rwhp
2017 F150 Lariat Scab, 5.0
Old 03-22-2013, 12:17 PM   #5
MustangGT02's Avatar
My grandpa's 05 GTO had this bad too, its the IRS not holding it down like a solid would. Like the people above said, it can be taken care of.
MustangGT02 is offline   Reply With Quote
Old 03-22-2013, 03:14 PM   #6
SGTman's Avatar
+1 (IRS, wrong year)
SGTman is offline   Reply With Quote
Old 03-23-2013, 05:26 PM   #7
BossCNC's Avatar
Region: Arkansas
This car is a solid rear axle.
---------- Post added at 06:25 PM ---------- Previous post was at 06:21 PM ----------
Car is still at stock height. I've read that it's due mainly to the weak bushings and bad angle of the LCA...Ford made it something like 30% stronger, which might work if it was only made 30% more power than the GT.
---------- Post added at 06:26 PM ---------- Previous post was at 06:25 PM ----------
Did you have the same issues with hop?
Old 03-24-2013, 03:47 AM   #8
1 Alibi 2's Avatar
Had wheel hop before the suspension mods..
Old 03-24-2013, 09:01 AM   #9
BossCNC's Avatar
Region: Arkansas
Thanks for the tips.
11:03 AM
