Thoughts? - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > Shelby Mustang
Old 04-09-2013, 12:14 PM   #1
Jguida's Avatar
Thoughts?
Any one have any thoughts on these eibach lowering springs? Do they effect warrantee? Are they worry it?
Jguida is offline   Reply With Quote
Old 04-09-2013, 03:59 PM   #2
godsdisciple85's Avatar
I have those on my 07 gt500 along with the shocks struts and sway bars...they make the car look great they are a little stuff as most aftermarket ones but I love them...it's a perfect amount of drop
godsdisciple85 is offline   Reply With Quote
Old 04-09-2013, 04:13 PM   #3
Ubnbit's Avatar
How low did it go? Is that all you need?
Old 04-09-2013, 04:51 PM   #4
Jguida's Avatar
It's 1.2 in the front and 1.5 in the rear
Old 04-09-2013, 05:45 PM   #5
Ubnbit's Avatar
Old 04-09-2013, 06:05 PM   #6
Ubnbit's Avatar
Old 04-09-2013, 06:11 PM   #7
Jguida's Avatar
I have no idea lol that's why I'm asking here's the picture from the site
Old 04-09-2013, 06:17 PM   #8
Ubnbit's Avatar
Lol. I hope the answer is yes but that's not my luck. I wonder if those are the stock size wheels on that car?
That looks sooooo sweet.
Old 04-09-2013, 06:25 PM   #9
Jguida's Avatar
That's the SVTPP so yes stock 20's rear 19's front
Old 04-09-2013, 06:51 PM   #10
DerekJohnScott's Avatar
It looks good lowered, but a stiff ride gets old quick.
DerekJohnScott is offline   Reply With Quote
Old 04-09-2013, 08:32 PM   #11
The stuff ride is only bad on real bumpy roads....and you will need an adjustable panhard bar...j&m $100
Edit: you may also need an alignment done but mine didn't it was perfect
Old 04-09-2013, 10:14 PM   #12
3dStang's Avatar
Just did mine a few weeks ago. Easy DIY job with a jack and basic tools(and spring compressor which you can rent from autozone. The hardest part was compressing the struts to remove the old springs. Got it aligned with no problem. I did have to order an adjustable panhard bar since my axle shifted about a 1/2 inch on the drivers side. It installed easy also. I have the '12 SVTPP it looks great and no real change in the ride. Well worth it. I'm actually going in for a TSB for noise with the front bushings that occurs backing out of my druvrway(apparently common on 10-12 cars) so well see if it effects warranty on the suspension. FYI, it made the noises prior to install. I attached before and after shots. When it finally settled it dropped 1 3/4 in bs k and 1 in the front.
ID:	101698   Click image for larger version
3dStang is offline   Reply With Quote
06:46 AM
