13 Shelby gt500 problem , HELP!!! - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > Shelby Mustang
Old 02-25-2014, 01:19 PM   #1
I have a 2013 gt500, i love the car and runs perfectly until the oil light suddenly came up on the dash, so I took it to the dealership to see what is wrong, they found out that the oil pump is broken and they fixed it.
After few weeks the car has lost it's power at all, I noticed that air/fuel ratio drops below 10.00 and boost doesn't not go above 5psi with WOT. I took the car to the dealership and they said that the catalytic converter is blocked, so they replaced it with a new one. However the problem is still there but they are saying that the reading is fine and nothing wrong with my car, but AGAIN it has the same issue. Same air/fuel ratio same boost problem. I could not find out what is the issue.
Suggestions please.
Many thanks.
13gt500 is offline   Reply With Quote
Old 02-25-2014, 04:24 PM   #2
EastTNMustang's Avatar
How long/how far did you drive the car after the oil light came on?
EastTNMustang is offline   Reply With Quote
Old 02-26-2014, 06:49 AM   #3
I stopped immediately, tow it to the workshop
Old 02-26-2014, 08:45 AM   #4
Take it to another dealer
Old 02-26-2014, 08:12 PM   #5
Chip's Avatar
Ditto - take it to a different dealer.
Chip is offline   Reply With Quote
Old 02-27-2014, 04:03 PM   #6
Notorious_rob's Avatar
I wouldnt trust em. New dealership!
Notorious_rob is offline   Reply With Quote
Old 02-28-2014, 11:18 PM   #7
godsdisciple85's Avatar
Sounds like the computer is still seeing the airfuel going to dangerous levels and protecting itself by not allowing you go full wot....have you had it tuned??? It could be that the cat was bad but the computer may need to be reflashed or could be that your airfuel is out of wack...? I would certainly take it to a more "performance" minded dealership that have the expertise to look beyond the surface of problem...
godsdisciple85 is offline   Reply With Quote
Old 02-28-2014, 11:19 PM   #8
Like bad wideband sensor...
02:41 AM
