Spare Tire I must have missed it - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > Shelby Mustang
Old 07-11-2014, 05:35 AM   #1
Mlarv5's Avatar
I was cleaning out my trunk the other day and decided to take a look a the spare to see if it was doughnut or a full sized spare. I popped up the bottom of the trunk and was surprised to just see a little air pump and an empty spot where a tire should be. I guess I can understand no spare because of the different tire sizes but, no jack either. I guess I am going to find a little jack to store in the trunk area just in case I need it. Anybody do this or is the little air pump enough to maybe get you on the road?
1968 Coupe <53000 miles on her 289 came off the line Jan 21st 1968. I bought it in 1983
2013 Shelby GT500 Born 12/06/2012 number 439 of 530 in DIB and 1 of 9 with Red Stripes over the top and on the seats
Mlarv5 is offline   Reply With Quote
Old 07-11-2014, 08:53 AM   #2
Yea Ford stopped putting them in. Should have an air pump and a little thing of fix-a-flat goo.
Old 07-11-2014, 09:06 AM   #3
Yeah, they basically have stopped. If I had ordered the Brembo package(wish I did), then I wouldn't have had a spare.
For the 15's, it's an option, I think.
Old 07-16-2014, 01:51 PM   #4
kingstrider's Avatar
Is this exclusive the Shelby cars? My 2014 GT has a full size spare.
kingstrider is offline   Reply With Quote
Old 07-16-2014, 07:33 PM   #5
If you have the Brembo option, you will have no spare tire.
Old 04-04-2015, 07:27 PM   #6
GTgeorge's Avatar
I was just as surprised as you probably was. I opted out and found a matching rim and bought a couple of tires and a jack so I could carry a full sized spare in the trunk. Haven't completed it yet but I'm sure my 19X9.5 won't fit in the well so I'll most likely fill the well with the compressor and the jack and have the spare robbing space in my trunk. I usually don't pack up my trunk with goodies anyway so the room won't be missed.
GTgeorge is offline   Reply With Quote
Old 04-04-2015, 07:39 PM   #7
Famine's Avatar
Region: South Dakota
I like it. Less weight to lug around.
Famine is offline   Reply With Quote
Old 04-04-2015, 07:47 PM   #8
GTgeorge's Avatar
Just don't get a flat. That fix a flat ruins you tire sensors.
Old 04-04-2015, 08:00 PM   #9
oxford5pointoh's Avatar
Yeah. The manual says to see your dealer after use. So not only do you have to replace the fix a flat canister but you have to have the tire dismounted, TPMS replaced, tire fixed or replaced then mounted and balanced and TPMS synced to the car. A flat could run you 125 bucks without a tire.
I have a brembo car and I bought an extra brembo wheel in eBay, a used tire and stuck it in the trunk.
It fits as long as the tire is only inflated to about 12 pounds. I drive too much to have to worry about being towed for a flat after trying the fix a flat only to find it won't fix the tire. I know it adds 60 pounds to my car but I am cool with that. If I go to the track it will come out.
Old 04-04-2015, 08:02 PM   #10
Noodles76's Avatar
I have a spare. Would I be able to fit a normal size 18x8 with stock tire back there? Anyone know
Rollin' in my 5.0
Noodles76 is offline   Reply With Quote
Old 04-04-2015, 08:03 PM   #11
Noodles76's Avatar
Nevermind I guess you answered that question!
Rollin' in my 5.0
Old 04-04-2015, 08:37 PM   #12
Rollin' in my 5.0
It will stick up a bit above the well. Just FYI. At least my 19x9 does. I think an 18x 8.5 will fit even better
Old 04-04-2015, 08:42 PM   #13
Not my car but here are some pics
Name:	ImageUploadedByMustang Evolution1428201747.558806.jpg
Name:	ImageUploadedByMustang Evolution1428201761.114165.jpg
Old 04-04-2015, 09:00 PM   #14
Famine's Avatar
Attachment 179112
Attachment 179113
Wow very nice. No noise at all with it not held down?
Old 04-04-2015, 09:53 PM   #15
Nope. It's snug as can be
Old 04-05-2015, 06:58 AM   #16
GTgeorge's Avatar
Also guys don't forget that with the lowered springs on these Shelby's if you get a flat and plan to jack it up to replace it with the spare that your going to have to deal with the jack not fitting under the body to fit your jack in.
Old 04-05-2015, 07:02 AM   #17
GTgeorge's Avatar
What you could do with the extra space under the spare tire is carry two pieces of wood 2x 6 's about 12" to 16" inches in length nailed together and mitered on the ends. This way if you get a flat you can place the wood under the flattened tire and back up onto it so the jack could fit.
Still a hassle but gets it done for you.
Old 04-06-2015, 12:53 PM   #18
Strange Mud's Avatar
George, I like that idea.
others. I'll also suggest a plug kit which adds minimum weight but often works w/o messing up TPMS. I bought a second set for my V6 to run in winter (summer only stockers) and for trips of more than 75 miles from hone I'll chuck one in the trunk.
Old 04-06-2015, 01:43 PM   #19
I drive 800 miles in a work week so that's every day for me
Old 05-16-2015, 09:26 PM   #20
Island Man's Avatar
Have 18x8 winters 19x9.5 summers need to have stock in a tire rack outlet to keep up with this BS. Bottom line think I've had 2 flats in my life so I go with just the inflate kit
Island Man is offline   Reply With Quote
Car mods, Have I missed anything? tarupert 2011-2014 Mustang GT 74 06-09-2013 01:21 AM
Help me put a spare tire in a '72 Fastback. jworkm72 Classic Mustangs 5 04-03-2011 04:30 PM
so what have i missed? Tbird232ci The Bar 20 12-05-2004 09:10 PM
Spare Size Tire Question Crispy Mustang Wheels & Tires 1 02-05-2004 05:59 PM
10:11 AM
