Boost drops - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > Shelby Mustang
Old 04-20-2015, 12:33 AM   #1
maldalo's Avatar
Boost drops
I just a 2.4 upper Pulley on my 2013 GT500 with the same stock belt, and I did a dayno run the boost start ok and then drops 2-3 psi and the picks up again near the cutoff. What could this be ?
And also the throttle which is stock too when I floor it , it does not open immediately, it opens gradually is the what causing the boost drop or vise versa ?
maldalo is offline   Reply With Quote
Old 04-20-2015, 12:41 AM   #2
natestang07's Avatar
Sorry I may be misinterpreting but if you replace the pulley with a smaller one you probably need to get a new tensioner, you may have some slippage
Old 04-20-2015, 07:34 AM   #3
1 Alibi 2's Avatar
How are you reading the boost, the dash gauge or a separate boost gauge ?
( the dash gauge may no longer read accurately after the pulley swap )
2014 - detuned to 780rwhp
2017 F150 Lariat Scab, 5.0
Old 04-20-2015, 08:47 PM   #4
Ubnbit's Avatar
Both of these guys are dead on. If you went smaller, you should definitely consider what they've already said. One of the 2 is likely the problem.
Old 04-21-2015, 02:57 PM   #5
maldalo's Avatar
I did install an idler pulley too to pick up the slack. And yes I read the boost in separate gauge. Some people say it's the belt so i will replace that with a new one and others say it's the throttle body and I'm not sure what's right.
Old 04-21-2015, 02:58 PM   #6
I would bet belt before throttle body.
Old 04-21-2015, 03:01 PM   #7
maldalo's Avatar
I went with JLT intake with the stock throttle body that could be a problem too ( bottle neck).
I'll replace the belt for now and do another run before I replace the throttle body.
Old 04-21-2015, 03:03 PM   #8
Might need a monoblade
Old 04-21-2015, 10:17 PM   #9
derick_snake08's Avatar
Try cleaning the mas, and tb.
Too much never enough.
derick_snake08 is offline   Reply With Quote
Old 04-21-2015, 10:21 PM   #10
javascript: { var vid = document.getElementById('video_1691355915'); if (firstTime) {vid.load(); firstTime = false;} if (vid.paused) vid.play(); else vid.pause(); }
I'm regard to the monoblade
---------- Post added at 09:21 PM ---------- Previous post was at 09:21 PM ----------
Sorry,
http://www.americanmuscle.com/13-14-...00-build3.html
Old 05-07-2015, 02:43 AM   #11
maldalo's Avatar
I replaced the belt and the throttle body now I don't see drop in the boost, but the boost now is increase gradually even tho I floor the peddle. The boost is supposed to be steady all the way until cut off not exponential increase. What do you think guys ?
Should I install back my original pulley and swap the lower pulley 10%
Or heat is a factor here as they say?
Old 05-10-2015, 07:35 AM   #12
Ubnbit's Avatar
Heat soak should only be a factor after you have ran it hard for a little bit. I swear it still seems like there is slippage somewhere. Once my boost kicks in, I'm gone. Until I let off. I can basically control it with the amount of pedal.
Old 05-10-2015, 12:23 PM   #13
Could have slack in it still. Maybe take a picture for us
Old 05-15-2015, 03:35 PM   #14
maldalo's Avatar
You can see the boost in greenClick image for larger version
Name:	ImageUploadedByMustang Evolution1431725735.223532.jpg
Old 05-15-2015, 07:30 PM   #15
Ubnbit's Avatar
What throttle body did you have on when you saw the drop in boost? When you installed the new one, did you tune the car?
Old 05-16-2015, 11:01 PM   #16
maldalo's Avatar
Ford racing TB 65mm and yes this is after tuning.
Now is it's 690 rwhp as I expected from the mods I installed but I still don't think that this the normal graph for the boost. Boost as far as I know should be steady horizontal line with no dips, even tho the rwhp matches what is expected from the package I installed .
Power just drops off SolidRRaxle 2011-2014 Mustang GT 8 08-26-2012 06:08 PM
Voltage drops 88stang5.0 1979-1995 Mustang GT 21 07-27-2012 08:29 AM
Boost line for boost gauge TooSlow4U 2011-2014 Mustang GT 0 07-20-2012 09:34 PM
More sweet back drops Silversky545 Pictures and Videos 11 03-31-2012 06:00 PM
Kyle Petty Drops F Bomb During Race Brent Pictures and Videos 11 06-25-2007 10:39 PM
09:21 PM
