Help pls!! Engine won't start sometimes... - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > Roush Mustang
Old 02-16-2014, 01:17 PM   #1
Roushracer80's Avatar
I have a 2006 Roush Stage 3 Mustang. Sometimes it won't start. I'll turn the key, and all I get is a click, no crank. I'll continue to turn the key off and on a few times, and finally the car will start. Can anyone tell me why this problem occurs? Any and all help with this issue will be greatly appreciated. Thanks to everyone here in advanced.
Roushracer80 is offline   Reply With Quote
Old 02-18-2014, 10:04 AM   #2
themauler's Avatar
Sounds like your tumbler is going out
I had to replace mine a couple different cars
Have to get the part from the stealership so it's coded to your key which takes a while to make.
themauler is offline   Reply With Quote
Old 02-18-2014, 06:47 PM   #3
Mile high JDF's Avatar
Before you spend any money check your connections. My guess is the battery isn't making good connections with the cables.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 02-19-2014, 09:06 AM   #4
Send a message via AIM to Destination S19
Had this happen in mine, it's a bad cell in the battery more than likely. It'll test good most of the time but it's bad. Get the battery replaced and it should resolve the issue.
FRPP HotRods Cams / American Racing Headers Long Tubes with catted X / Stang-Hi dyno tune
Saleen wheels / Steeda CAI / Corsa Xtremes, K Springs, Koni STR.Ts, UMI lca relo. Brackets/r lwr ctrl arms UMI adj. panhard bar / Camber plates / SR Strut Tower Brace.
Destination S19 is offline   Reply With Quote
Old 02-24-2014, 08:43 AM   #5
Thanks everyone for the advice, I will definetly look into this
Old 02-25-2014, 09:44 PM   #6
olds442111's Avatar
Send a message via AIM to olds442111
When this takes place, is the entire electrical system failing / shutting down? Is it a defined, hard click, like from the starter, or a soft click, like from the starter relay? The starter relay has been known to fail on these vehicles. I'm not saying go out and buy one and hope for the best. I'd investigate a little more before I went out and dropped money on a part on a hope.
White 2014 GT Premium / Blower / Auto Trans / Louisiana
Blue 2016 Sport FX4 Crewcab / Blower coming soon
olds442111 is offline   Reply With Quote
Old 02-26-2014, 11:16 AM   #7
The electrical system does not fail or shut down at all, and the click that I get when I turn the key is soft, like it's the relay, not the starter, but I don't know.
Old 02-27-2014, 12:01 AM   #8
olds442111's Avatar
Remove the starter relay and test it first
Old 02-27-2014, 01:38 AM   #9
Right on, I will do that, thx..
Old 05-12-2014, 03:37 PM   #10
Bongadier's Avatar
I was having this problem ...it was the switch when ya push the clutch pedal in to allow the car to start.... Look where the clutch pedal touches the sensor .. Sometimes it goes bad... Not saying that's it ... But it happened to me....
Bongadier is offline   Reply With Quote
Engine swap options? (2010 V6) Torch10 2011-2014 V6 Mustang 17 08-26-2013 07:38 AM
Mustang 2 motor swap. Curtiswhitehead 2.3 Mustang 2 07-10-2013 08:06 AM
Think i found out whats going on Maddhatter88 1979-1995 Mustang GT 30 06-08-2012 02:04 PM
Engine died at low speed. Could not start engine in hot weather Ucla1998 Pre-2005 V6 Mustang 5 08-09-2011 02:15 AM
3.8l to 4.6l engine swap important steps zrider07 General Mustang Discussion 2 08-04-2011 09:07 PM
01:32 PM
