Sub Frame Connectors? suspension upgrades - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > Roush Mustang
Old 01-23-2015, 09:50 AM   #1
Recently I bought some BMR suspension upgrades. The LCA's, relocation brackets, panhard, and sway bar. One thing I completely forgot about until doing the install, was the subframe connectors... The factory set up appears to be very weak when looking at it.I will have to pay a shop to do that install seeing that they are welded on. I was wondering which ones people are recommending or using? Chances are I will stick with BMR since my other products are as well and I am extremely happy with them! By the way guys, the MGW race spec short shifter has to be my best upgrade yet. It is bad ***!!! Highly recommend, and if you buy from MGW, owner will do install free in Augusta GA
jamyzd30 is offline   Reply With Quote
Old 01-24-2015, 06:18 AM   #2
Blackpearl's Avatar
I am looking at BMR subframes right now myself. Most other owners say they are not needed on a 05 up street car. I like yourself, have upgraded several other suspension pieces, and would like to know I am taking full advantage of them. While the newer cars may not benefit like the older cars did, anything that makes the chassis more consistent and predictable is a "need" in my book.
2014 Mustang Roush clone. TSWs, O/R/X, Bama tuned, Airaid, Brembo brakes, BMR suspension ...awaiting the huffer.
2014 F150 4x4, leveled, Moto Metal wheels, 33s, Kicker audio, Roush exhaust, one off custom bull bar
2012 Challenger R/T. Mopar CAI, Flowmasers, staggered 20" Vipers...400HP and rides like a Caddy.
Blackpearl is offline   Reply With Quote
Old 01-27-2015, 08:51 PM   #3
I have decided to go with Steeda frame rail & torque box brace. For the 2014 you can only weld it in(no bolt on), ford made a few changes according to Steeda. Nonetheless, I would weld it anyways. It will most like be a few weeks/months before I can buy and install it. I will keep you posted as to the progress and If I am happy with it or not. Time to work some OT....hope it's worth it
Old 02-28-2015, 01:48 PM   #4
I had the Steeda frame rail/torque brace connectors welded on a few days ago. Honestly, the design of them seems sub-par...You can bolt in a few areas to hold in place while you weld, it connects to your lower control arm bracket, but does not go through the inlet hole...It welds prior to it. I am sure this is more then enough to hold, I just expected a better design or fitment. Anyways, a piece of mind. I know a lot of mustang guys claim we don't need them anyways, but sheet metal connecting without anything else seems weak to me. Anyways, I installed the Steeda one piece drive shaft...Now that is a different story. That was well worth it!!! Car feels lighter and the tires are breaking loose all the way through 2nd gear. It will take me a while to adjust, spinning ain't winning, that's for sure. Anyone wanting pictures, message me...I don't know how to add, sorry.
Phase 3 upgrade including CAI, Fuel pump voltage regulator, (648rwhp), 582 torque, Kooks LT headers with off road H pipe, Vossen CV3's, ID1000's, Steeda Heat Exchanger, BMR LCA's,relocation brackets, adjustable Panhard bar, Rear sway bar, Steeda Aluminum driveshaft, X-brace, Differential cover, torque box brace/frame rails, Shelby trans cooler, Mcleod RST clutch/lightweight steel flywheel w/SS clutch line, RP fluids, whiteline transmission bushing,MGW race spec short shifter,Ford racing twin 65mm throttle body, Pro Dyno tuned
sub frame connectors jdavis96gt General Mustang Discussion 8 06-26-2012 08:20 PM
Sub frame connectors southernstang00 1996-2004 Mustang GT 23 06-06-2012 10:44 PM
Sub Frame connectors? davidr_1961 1996-2004 Mustang GT 28 02-25-2012 11:11 PM
Sub frame connectors jhagan1980 General Mustang Discussion 3 11-19-2011 11:59 PM
Ride hight & sub frame connectors 96 stang 1996-2004 Mustang GT 8 04-06-2011 11:14 AM
05:14 PM
